I picked one of these up in m42 mount with a k-mount adapter. Focus is super fast with the squeeze grip. The DOF is super shallow at 5.6. Wish it had an A setting for the apperture. Its really hard to focus when its not wide open. I liked the images a bit better at f8.0. I did some shots with the k20d and it metered pretty good. Then I slapped it on the gx-1l (ist dl). Metering was way off, had to use it in manual mode. Here are a couple samples.
First is with the k20d, second with the gx-1l, neither are cropped, some adjustments and a little sharpening with the re-size. The sun disappeared before i could switch cameras.
