04-14-2007, 04:52 PM   #1
mediaslinky's Avatar
Non-coated lenses and filters... reduce glare/flare?
If you have a non-coated lens that had a tendency to flare, would some sort of filter help? If so, what kind?
04-14-2007, 04:56 PM   #2
Dana G's Avatar
QuoteOriginally posted by mediaslinky Quote
Probably not. If you do add any glass, make absolutely sure it's multi-coated.
A good lens hood and careful shading of the lens will also help.
04-14-2007, 05:04 PM   #3
No. Dana is spot on.
04-14-2007, 05:26 PM   #4
MRRiley's Avatar
I concur... A superior grade multicoated filter MIGHT help, but the best thing is a good lens shade. I once had a 200mm with plain glass and I ended up mounting an extra long shade and trimming it down until it no longer vignetted the image. It ended up looking a lot like the modern petal shaped hoods (I shoulda patented it then and there dang it). This helped a lots but if the sun or a strong reflection was able to get straight in it was flare-city. I wouldnt avoid an un-coated lens if the price was right but you have to be aware of their limitations.
k-mount, pentax lens, slr lens
Any way to reduce on-board flash output with manual aperture lenses? Eruditass Pentax DSLR Discussion 9 04-08-2010 10:00 AM
multi-coated clear filters? grey goat Pentax SLR Lens Discussion 3 01-25-2010 01:34 PM
Lens Filters versus Flare and Ghost Images K200D Pentax Camera and Field Accessories 1 09-08-2008 03:06 AM
digital multi coated filters madisonphotogrl Pentax Camera and Field Accessories 7 03-22-2008 01:17 PM
multi coated filters jpl Photographic Technique 1 07-17-2007 01:54 PM
All times are GMT -7. The time now is 09:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
