05-18-2009, 11:57 AM   #31
QuoteOriginally posted by pcarfan Quote
Extension tubes with A contacts are rarer than hen's teeth, some of us are converting old cheap (~$25-35) TC's into ext. tubes. These are identical to the TC's sold as ext. tubes.
I had to destroy the first one trying to pry open the whole thing, but now I have learned the proper technique and it is as easy as unscrewing the center element.
Hope this helps.
This helped me very much. I finally had the courage to take the insert out of my Viv 2X with the electrical contacts. Now I can have macro from any of my prime lenses, without carrying my big, heavy new toy, the Viv 100 2.8 macro I recently traded my DFA 100 for with another member on this forum. Not having sellers remorse, but dont know whether to keep the Viv macro now.......
12-27-2009, 10:17 AM   #32
Mike.P's Avatar
Just to resurrect this thread for a while, I was given an old 2x TC with A contacts and as I have others that are a lot better quality I decided to give this a go. Couldn't get hold of the internal piece with the grips so had to smash the glass first and grip it partially from the inside but it unscrewed fine after that.
Attached it to a FA 50mm f1.4 and this is the result.
Bubbles in a glass of lemonade.
12-27-2009, 10:30 AM   #33
pcarfan's Avatar
I use it with my F135/2.8 and love it. But, it only works with one 25mm TC. I got three others and tried it as a 50mm,75mm,100mm TC and none of them worked well, as the center of the image didn't look right.
Here are some 135/2.8 shots with these modified TC
12-27-2009, 04:27 PM   #34
Mike.P's Avatar
Home made tube on a Sigma 70mm f2.8 macro lens.
ext, k-mount, pentax lens, slr lens, tubes
Convert Ron Kruger Welcomes and Introductions 4 08-27-2010 08:51 AM
hair/dust showing on pictures? sara Pentax DSLR Discussion 11 07-29-2010 11:34 PM
new convert netoyen Welcomes and Introductions 4 08-24-2009 11:38 AM
AF Ext Tubes JCSullivan Pentax Camera and Field Accessories 12 10-03-2007 05:06 PM
All times are GMT -7. The time now is 03:09 AM. | See also: NikonForums.com, part of our network of photo forums!
