04-23-2009, 08:14 PM   #1
sigma 10-20 underexposured images
I have just bought a sigma 10-20mm from the forum and today i had a few minutes to take a couple of test shots - feeling lazy i just set the camera to auto and fired a few shots which turned out underexposed:
If i set the exposure to 0.5-1 above the images appear much better. Anyone else having this problem? or had?
heidi
04-23-2009, 08:30 PM   #2
He is an example of what i mean:
[IMG][img=http://img2.imageshack.us/img2/6551/005nom.jpg][/IMG]
04-23-2009, 08:33 PM   #3
Andi Lo's Avatar
Slight over or underexposure with certain lenses is very common. Don't worry about it. The behaviour is usually constant so if you know your lens, it shouldn't be a problem. More important is where you take your meter from in the image. If you meter from the sky, the ground will be underexposed. If you meter from the ground, the sky will be overexposed.
04-23-2009, 08:36 PM   #4
I think those white clouds are the reason. Pentax cameras are known to cut back on the exposure in order to avoid blowing highlights. This is specially true if you have the exposure setting on multi point exposure. Perhaps you get closer to what you think it should be by using the "average" eposure setting.
04-23-2009, 09:18 PM   #5
Marc Sabatella's Avatar
Not just the clouds, but the sky in general is causing the camera to expose the way it is. If it exposed the forground to look good, you'd lose most of the color in the sky. Maybe that's what you wanted, but the camera can't read your mind. How is it supposed to know you didn't *want* a well-exposed picture of the sky with a dark foreground, as opposed to a well-exposed foreground with a washed out sky?
04-23-2009, 10:13 PM   #6
Jewelltrail's Avatar
You can use Graduated Neutral Density filters to obtain a more even exposure for the sky and ground.
04-24-2009, 12:08 AM   #7
axl
agree with what's posted above. 10-20 has so great FOV that it's very easy to have something bright in there that'll throw off the metering, especialy when using multisegment metering. Try to stick with spot or CW metering and meter of neutral tones before taking shot.... But 10-20 still may need 0.5-0.7 + Ev compensation...
BR
04-24-2009, 01:02 AM   #8
James S
Guest
G day Heidi.
I've found with most of my sigma lenses I've owned, including the one you have that in certain conditions, you need to push the EV +/- up or down. I wouldn't be too concerned about it.
Enjoy the lens.
images, k-mount, pentax lens, shots, sigma, slr lens
Landscape First images Sigma 18-50 f2.8 bychan Post Your Photos! 0 01-24-2010 02:22 PM
Sigma 17-70mm Thread w Images? rustynail925 Pentax SLR Lens Discussion 7 11-30-2009 05:50 PM
Birding with the Sigma Sisters (10 Images) daacon Post Your Photos! 19 06-09-2009 04:15 PM
first sample images from Sigma 70-200/2.8 II kenyee Pentax SLR Lens Discussion 4 03-29-2008 10:11 AM
Sigma 17-70, great lens (2 images) simonkit Pentax SLR Lens Discussion 9 09-01-2007 03:51 AM
All times are GMT -7. The time now is 04:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
