Upon reading another thread found
here, I purchased a Nikkor 105mm at a camera show. I got a good deal for it because a previous owner had tried to modify it, but only got part of the job done.
Here are some photos of the lens in question (These photos are post-modification):
The first thing I did was use an orbital sander to make the aperture ring narrower. This will give the mount a bit more clearance.
In order to do this, i had to remove the aperture ring altogether. This was easy to do once I removed the retention screw and the aperture ring just screws off.
The retention screw also moves the aperture blades open and closed by moving a slot back and forth. When putting the aperture ring back, it's important to keep this in mind and make sure the retention screw is lined up with the slot.
Once that was done, I drilled a whole in the mount collar to get the lens to lock on to the lock pin on the camera. You'll notice that I drilled two holes. The one on the bottom was an earlier miscalculated hole.
It's not pretty, but I'm perfectly confident that I won't drop it by accident. One thing to keep in mind is that a drilled hole will be tapered if it is shallow and the lock pin will simply slip out. I had to grind the hole so the side that the lock pin grabs onto was perpendicular instead of sloped.
Let me know if you're interested in sample pictures, I'll try to take some and post them.
