04-24-2009, 08:45 PM   #1
DA 70 Limited Build Quality
Just a quick question for others who own the DA 70 Limited. I recently added one to my collection and have noticed that the barrel is a bit loose front to back. When focused to 1.3m the play when lightly pushing/pulling on the barrel is quite noticeable compared to my DA 35. Is this normal for the lens?
04-24-2009, 10:17 PM   #2
Silly question, but maybe it's the movement from the lens hood?
I'll have to check my own to see if I can do the same.
04-25-2009, 04:13 AM   #3
Torphoto's Avatar
QuoteOriginally posted by legacyb4 Quote
Quite possible as my 70mm is tight and solid, but the hood isn't
04-25-2009, 07:16 AM   #4
QuoteOriginally posted by Torphoto Quote
This is definitely the barrel. Even when using the focus ring there is a bit of looseness before it catches and moves the barrel in or out. Sounds like it might be worth a trip to Pentax to get checked out.
04-25-2009, 11:00 AM   #5
Torphoto's Avatar
well my well used DA 70 is tight, no play or wobble front or back or side to side but do remember the focus ring is undamped make sure it's not this either.
04-25-2009, 01:44 PM   #6
Marc Sabatella's Avatar
I don't notice an unusual amount play in my barrel either, but the hood definitely likes to move around on its own, and spends a good deal of time kind of cocked at an angle, mostly retracted but partially portruding on one side, until I push it back in.
04-26-2009, 08:23 AM   #7
QuoteOriginally posted by lowbit Quote
I sent my lens in to Pentax for this reason. It seemed like a whole lot of play for a Limited lens (I had them all at the time). The repair notes say they did some minor adjustments but ultimately I didn't notice a difference. I think that's just how the lens is and it would be a waste of time for you.
04-26-2009, 07:55 PM   #8
QuoteOriginally posted by frostugh Quote
Interesting and thanks for all the replies on this. So far optically nothing seems out of sort. I'll likely keep working with it and if I want to send it in, will do so before the one year warranty is up just to see if they can improve it.
04-27-2009, 11:07 AM   #9
MShawn63's Avatar
The only play I see in mine is the sun shade it slides really easy but I don't see any other issues with it. Then again I've only had it a week.
barrel, da, k-mount, pentax lens, slr lens
Dropped a lens! (DA Limited build quality?) ADHWJC Pentax SLR Lens Discussion 10 10-16-2010 10:01 PM
Build quality of Pentax Limited lenses? ducdao Pentax SLR Lens Discussion 22 05-16-2010 06:31 AM
DA 12-24mm build quality SylBer Pentax SLR Lens Discussion 26 04-07-2010 11:06 AM
AF lens build quality? ChrisPlatt Pentax SLR Lens Discussion 6 05-28-2008 05:13 PM
Build Quality patrickt Pentax SLR Lens Discussion 3 04-27-2008 09:32 AM
All times are GMT -7. The time now is 06:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
