04-29-2009, 04:39 AM   #1
pcarfan's Avatar
Anyone using long ext. tubes ?
I have been experimenting with ext. tubes with my FA77, FA43 and the Sigma 100-300 F4...they work, but I feel like with long ext. tubes (100mm) the corners remain tack sharp, but the center gets fuzzy. Also, with the 100-300 I see a round lighter area in the middle of some images.
Anyone who has used ext. tubes longer than 50mm, can you please give me your experience with them and what lens you used.
This thread which clearly showcase some of the finest macro work ever, involves 100mm ext tubes, so it should work.
Thank you
04-29-2009, 05:08 AM   #2
I have used very long extension tubes, including different bellows, up to 20cm+ with many different lenses ( Pentax macro DFA 50mm , cine lenses ( D - C mount ) , special macro lenses like the tominons ) etc etc
I have never seen what you describe ( better corners , fuzzy center ) .
Maybe you could post an example to clearly show what you mean .
Longer tubes than 100mm will have a great impact on diffraction. Don't use very long lenses ( long lenses = longer than 100mm ) with ext.tubes to gain high magnifications. If you use very long tubes ( 20cm ) for high magnifications ( 10x magnification ) make sure you choose an aperture typically not more than F11, then diffraction kicks in and its really obvious , the image becomes very fuzzy and not sharp at all .
I can post you some examples of 20cm + reversed pentax dfa 50mm if you want , they are really sharp.
04-29-2009, 05:12 AM   #3
pcarfan's Avatar
Thank you...
I will post some images times I take the time to upload to post these images only to find that the thread dies without a reply. DSo, wanted to make sure there are people in here who can help me.
I will take some shots later today.
04-29-2009, 06:13 AM   #4
Nesster's Avatar
Without seeing samples and just guessing off the top of my head:
- the reflections from inside the tube may be messing with the center of the image
- field curvature at such a magnification may make it so that the edges are in focus while the center isn't, or vice versa
04-29-2009, 08:32 AM   #5
pacerr's Avatar
Try reversing the lens on the extention tube. That MAY help depending on the particular lens combination. Sometimes. Maybe.
Actually, I've found ultra-macro to be a crap-shoot depending on the equipment combinations. But fun when you have the time to experiment.
04-29-2009, 08:42 AM   #6
timbo13's Avatar
I'm with Nesster on this one, it sounds like field curvature. I see it when I use my M50/1.7 on a macro bellows.
100mm, ext, k-mount, pentax lens, slr lens, tubes
Shake reduction on ext tubes ? Transit Pentax DSLR Discussion 17 03-13-2009 05:47 AM
First outing with Ext Tubes Damn Brit Photo Critique 11 01-11-2009 12:06 AM
Macro...rings, ext tubes, lens ronald_durst Pentax SLR Lens Discussion 11 10-27-2007 03:28 PM
AF Ext Tubes JCSullivan Pentax Camera and Field Accessories 12 10-03-2007 05:06 PM
All times are GMT -7. The time now is 07:25 PM. | See also:, part of our network of photo forums!
