05-05-2009, 01:26 PM   #16
Lowell Goudge's Avatar
one ting I find with a 28mm MF lens is that the DOF is so good, you can't easily focus withouot a split image.
how are you focusing this lens.
I have 2 different 28mm lenses vivitar F2.5 and tamron adaptall F2.5, I have seen things like this from poor focus just because it is so hard to get it perfect without split image
05-06-2009, 08:39 AM   #17
res3567's Avatar
Some people like to use metal foil to short the electrical contacts when using certain lenses on certain cameras in order to fool the exposure & metering system into behaving differently. Can workaround certain types of exposure problems that occur with certain manual lens / camera combinations. If you don't have problems, then you don't need this (potentially dangerous) workaround. If you do have problems, you might try Googling for "foil" along with information about the specific problem you are seeing, to see if there is a simialr workaround for your particular problem.
Have you had to use that?
05-06-2009, 02:14 PM   #18
Marc Sabatella's Avatar
No, I have not.
effect, ghost, k-mount, look, pentax lens, pictures, slr lens, wizards
SR causing double images on K-m nick c Pentax DSLR Discussion 3 08-30-2010 05:53 PM
what's causing this weird yellow tint ? chiem Pentax DSLR Discussion 17 03-11-2009 06:43 AM
IE causing problems with posts? FHPhotographer General Talk 14 01-22-2009 01:16 AM
any idea what's causing this? FHPhotographer Pentax DSLR Discussion 15 12-08-2008 12:50 PM
IR effect on K10D Ash Post Your Photos! 2 05-01-2008 03:14 PM
All times are GMT -7. The time now is 02:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
