05-05-2009, 06:40 PM   #1
Stuck filter, help please!
I sold my FA 50mm 1.4 to one of our members in this forum. I had a filter attached to it when i sold it. But ther was a problem, he said he cant removed the UV filter I attached to it. Do you have any suggestions how to remove the filter?
05-05-2009, 08:14 PM   #2
res3567's Avatar
QuoteOriginally posted by jadem Quote
I would say vice grips.
That may damage the lens, however.
Did you install the filter and was it hard to turn?
It could be cross threaded.
05-05-2009, 08:19 PM   #3
F16
One of those rubber jar openers. Some also say to use the bottom of a mouse pad, it's often a very 'grippy' rubber sponge material. Put a fair amount of force on the lens, face down on the mouse pad, turn... Or clamp the filter in a bench vise if you get desperate enough, obviously don't overdo it on that either.
05-05-2009, 09:20 PM   #4
Lowell Goudge's Avatar
there are filter wrenches for lenses that work great. especially separating filters
Amazon.com: Adorama Filter Wrench for 62mm-77mm Filters, Package of 2: Electronics
05-06-2009, 03:13 AM   #5
and
I kept having this problem with the DA 12-24 and a 77mm polarizing filter. The filter had grooves on the outside of the ring so I used a coin that also had grooves as a sort of toothwheel to get it open
05-06-2009, 07:29 AM   #6
Guys, thanks for your suggestions. I will try to forward your suggestions to Kaltarr, the onw who bought my lens.
filter, k-mount, pentax lens, slr lens
Filter stuck on lens. Suggestions? Zeroset Pentax SLR Lens Discussion 50 03-21-2012 07:45 PM
UV filter stuck on lens netuser Troubleshooting and Beginner Help 9 10-18-2010 08:40 AM
stuck lens filter widget Nass Photographic Technique 17 04-11-2010 06:32 AM
Help! Filter stuck on lens. Spock Pentax SLR Lens Discussion 14 11-24-2009 11:05 PM
Filter stuck in reduction ring rience Pentax Camera and Field Accessories 4 02-08-2009 08:20 AM
All times are GMT -7. The time now is 06:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
