05-06-2009, 03:28 PM   #1
julianactive
Guest
Shake reduction
xxxxxxxxxx
05-06-2009, 04:05 PM   #2
Dom
Guest
QuoteOriginally posted by julianactive Quote
Has anyone just turned off SR for hand holding? Can you get clearer pictures without it provided your hand is steady enough and your shutter speed is high enough?
I've been taking photographs without shake reduction for the last 25 years.
05-06-2009, 04:13 PM   #3
Clearer? Under most circumstances, I sincerely doubt it. If the mechanism is working correctly, it shouldn't ADD any movement, only cancel it.
(Granted, "if the mechanism is working correctly" may be an unwarranted assumption. But in my experience, it works pretty well.)
As clear? Sure! If you hold steady enough, or the shutter speed is high enough, no problem. As Dom said, that's how it used to be done!
k-mount, pentax lens, slr lens
Do you always have shake reduction ON? gawan Photographic Technique 18 08-01-2010 02:36 PM
Shake Reduction Help TimShadler Video and Pentax HDSLRs 10 11-30-2009 01:56 PM
Thank you Shake Reduction! tcdk Post Your Photos! 4 09-03-2008 09:29 AM
Shake reduction not on? Iowa Tom Pentax DSLR Discussion 9 08-11-2008 04:00 PM
shake reduction jay legere Pentax DSLR Discussion 7 01-20-2008 07:45 AM
All times are GMT -7. The time now is 11:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
