Originally posted by alehel Is there some way I can add to the exif the missing information when using an old manual lens? I'd like to be able to add the lens name and what aperture I took the shot at.
Raising the dead here, but thought I might inform latecomers about the
command line utility `exiv2` which can be used to retrieve/list and modify all EXIF and IPTC information. I often use it to do exactly what the poster wants; adding EXIF data to pictures that lack some of it. For instance, I add capture dates to scanned film photos using this script:
Quote: #!/bin/bash
# @depends on exiv2
if [ "$1" == "" ]; then
echo "usage: $(basename $0) '2002:07:22 00:00:00' picture.jpg "
else
exiv2 -M "set Exif.Photo.DateTimeOriginal $1" $2
fi
# vim: syntax=sh
On unices such as Linux and mac os you can save it and make it executable. You can easily modify it to set any other exif value to make it possible to alter hundres of files in seconds.
