Originally posted by Edicon How do I de-pinned the lens?. Sorry, never done it before. Thank you.
Hmmm 'de-pinned' ... Sorry about the made-up word - didn't mean to confuse. Just an attempt at obscure humor.
The link to the 'Ricoh Pin Fix' article that ftpaddict pointed out is the original article I used as a guide to 'correct' my P/R lenses.
A couple of hints: Use good screw drivers like the better grade Wiha Phillips screw drivers. A stripped screwhead is a real PITA. Plus some manufacturers use a little Lock-tite on the screws so take care trying to remove them. Also you might take 'before' photos to use as a guide for the re-assembly. Oh and work in a spot where you hopefully can find little-bitty screws if they slip and bounce...
Edit: If you are planning to modify the lens in your original post the comments by axl are still true. The flange I circled will have to be modified to even mount the lens to your camera body. Here is an
example of the flange removal on a Vivitar. Your lens may differ in the procedure. Here is another link showing the flange modification:
Vivitar Flange Interferrence Fix
Best of luck!
John
