Originally posted by alexfoto I have a question.
How is simple use this len (without using a split prism) to shoot subject in movement as for example the second shoot?
Well... between the very shallow DOF and the manual focus, it's kind of hard, but not much harder then AutoFocus. You have to motor the lens yourself, and with a bit of training you'll probably be better at predicting how to turn it then AF-C.
But if you have any kind of fast lens, try to put it in manual focus, and play with it. The first shots will be frustrating, but hopefully you'll quickly get the hang of it. I simply switch to AF-S, half-press and work the focus until I have a red square AF confirmation, and then I full press when I want to take the shot. If I've lost focus in the wait, I'll simply have to jiggle the focus a bit to get a new focus and the camera will fire.
Only thing I miss is the ability to select focus point, as I've started to use one of the side points as my main, to get more off-center compositions...
