Originally posted by Big G Hi All,
I bought a 50mm f/1.7 Pentax M lens for a wedding and also for a test lens to see if I would actually use/like a 50mm prime. Turns out, I absolutely love it for portraits but I would really like one that autofocuses and is silent. I missed a few shots at that wedding because I couldn't manually focus fast enough and I also noticed people were reluctant to stand still for too long, so I would really benefit from an autofocus prime.
I've got my eye on the Pentax DA* 55mm f/1.4, but the Sigma 50mm f/1.4 seems to have had brilliant reviews and not a bad word said about it.
My only problem is that everywhere seems to be out of stock of it, or has it listed as "on backorder" for a Pentax fit. Is it not available yet? Has anyone managed to get hold of one?
Here's a review of a Canon fit -
Sigma AF 50mm f/1.4 EX DG HSM (Canon) - Review / Test Report - excellent sharpness wide open and CA is controlled very well.
Big G,
You didn't mention the aperture you were shooting...but if it was at f/1.7~2.0 when you missed the shots you may consider these points:
1) The DOF is extremely limited, so focus is absolutely critical. I'm not sure that AF would totally resolve that issue, perhaps others can comment in that regard.
2) If you are using the stock focusing screen that came with the K10D, then it can't resolve less DOF than f/4. A split-image focusing screen is the way to ensure accurate focus.
A split-image screen + a bright 50mm is quite quick and accurate to focus and stopped down to f/2.8 adds enough DOF.
You may want to eliminate these variables before dropping a big sum on an expensive lens.
In autofocus, I would choose the DA*55 for one simple reason: quick-shift focusing. This killer feature is the best of both worlds.
