05-15-2009, 03:55 PM   #1
skinja's Avatar
What are the odds that my new 16-50 will be a good copy
I ordered a 16-50 from B&H on Wedensday, It's sitting at home waiting for me.
I'm a little skeptical that the first one will be good. I just couldn't help myself, I am a little short on the 16-28 range at 2.8
If you go by all the reviews I think I have about a 65% chance of getting a good one first time.
I will know in about 3 hours.
05-15-2009, 03:59 PM   #2
rpriedhorsky's Avatar
Keep in mind that people with negative experiences are much more likely to post evaluations (people with positive experiences tend to just use the thing and not worry about telling others). So, I'm sure your odds are considerably higher than that.
05-15-2009, 07:29 PM   #3
skinja's Avatar
Bad
9030404 is on it's way back. going for round 2
05-16-2009, 12:13 AM   #4
nulla's Avatar
This is my most used lens.. a good copy is great
Neil
05-16-2009, 09:20 AM   #5
skinja's Avatar
I should have bought this lens a month ago
Now becuse I am so impaitent I will have two at the same time. B&H is closed until tomorrow so I ordered one from Amazon and it will be here Monday. My wife will probably be handing one to the UPS driver when he drops off the new one.
I hope I don't need to purchase a third one. Wish me luck
05-16-2009, 07:57 PM   #6
What was the problem with the first one? I had to adjust for front focus on mine, but after that it has been just great. I use it about 90% of the time now, only switching when I need longer or faster, which isn't that often.
05-17-2009, 10:00 AM   #7
skinja's Avatar
Corner sharpness
Newspaper test. The center two thirds of the picture is spot on its the out side edges/corners that are the issue, the top left corner or so is so blurry its unreadable the bottom right corner was better but not good the other two corners were some where in between. this was from 2.8,4, 5.6, 8 to f11 at 16mm, 30mm, and 50mm.
This was done on a tripod with a remote and 2 sec timer set.
checked for squareness to the wall.
My 18-250 performed better at the same available apatures and focal lengths.
05-19-2009, 10:33 PM   #8
skinja's Avatar
The odds improve greatly if you try twice
All though not perfect the second lens is much much better. The Lower right corner seems to be the trouble maker on the second lens.
Sorry I haven't posted any of the test results as of yet, life has been getting in the way.
testing was very informal just a newspaper shot at various ap's and focal ranges, simple and to the point and if your happy with the results no more testing required. This is not something I would normally do, but for this lens I'm glad I did.
I will post on flickr shortly after the first if your interested
05-20-2009, 12:10 PM   #9
rfortson's Avatar
QuoteOriginally posted by skinja Quote
What camera do you use? I was very unimpressed with my 16-50 on my K10D, but it became a much better lens on my K20D. Purple fringing was non-existent, and focusing seemed much better.
05-20-2009, 04:42 PM   #10
skinja's Avatar
Both
QuoteOriginally posted by rfortson Quote
I have both a k10 & k20, I actually use the k10 more then I do the k20. I shoot a lot of pictures for work and the quality of the k10 is more then adaquate for this and it is a really dirty enviroment, just can't justify taking the K20 to work.
The 18-250 is on my K10 always, the 16-50 has not meet the K10 as of yet.
I have been working so many damn hours lately, I havn't had any time to take pictures out side of work. 400 hrs in 28 days
05-20-2009, 05:07 PM   #11
PentaxPoke's Avatar
skinja,
you are going down the same path I did. I stopped after the 3rd try. Tamron 17-50 is a much better lens in terms of sharpness. Even wide open. I have two entire threads on my experiences with these lenses.
k-mount, pentax lens, slr lens
what is a good or bad copy of Da*16-50? nuaabill Pentax SLR Lens Discussion 20 11-13-2009 07:26 PM
Help - bad or good copy 16-50 ? Vaikis_ Pentax SLR Lens Discussion 4 10-17-2008 04:54 AM
DA*16-50... Is this a good copy??? Urgent! Apfel Pentax SLR Lens Discussion 4 08-30-2008 04:47 PM
Sigma 10-20.. it's a good copy !! simonkit Pentax SLR Lens Discussion 6 08-24-2008 11:57 AM
How can I test to make sure I have a good copy? Ed in GA Pentax SLR Lens Discussion 2 01-13-2008 08:58 PM
All times are GMT -7. The time now is 02:40 PM. | See also: NikonForums.com, part of our network of photo forums!
