05-18-2009, 07:08 PM   #1
jack56's Avatar
I got an SMC Pentax-M 50mm f 1.4 today.
I just got an SMC Pentax-M 50mm f 1.4 today. In great shape... see pics below.
Problem was... I couldn't get it to work on my Pentax K10D?
I tried the Manual focus w/manual setting on the dial and all I'm seeing on the top LCD is a blinking F - - ?
Then I read page 35 and 210
p35: Lists custom menu options, including the option to allow the camera to release when the lens is not on "A" or has no "A"
p210: Lists the metering options for various classes of lenses, provided the custom option to allow shooting when the aperture ring is not on "A" has been properly set.
Here is the first photo I took with the 50mm. Still have to learn the settings.
What kind of lighting situations would the M 50mm f 1.4 be best suited for over the standard 18-55mm zoom lens I have now?
05-18-2009, 07:20 PM   #2
Andi Lo's Avatar
The 50mm would be nice for low light, and when you want to create bokeh shots.
Prime is nice in general because you have to work harder to create the picture, so usually it's more refined than when using zooms.
AFAIK the f-- is normal and you change aperture using the aperture ring. Everytime you want to shoot, press the green button in M mode so and the shutter speed will be set for you.
05-18-2009, 08:56 PM   #3
Marc Sabatella's Avatar
There is basically no situation where the 18-55 will outperform the 50. The only question is, in which situations will the 18-55 do well enough that you will choose it for the convenience of zoom, AF, & autoexposue rather than the 50. Basically, if you don't need to be shooting wider than f/8, there is little reaosn to prefer the 50 - it's advantage will be relatively minimal. But at f/5.6, the 50 will smoke the kit lens, and the kit lens can't go wider than that at all at 50mm.
50mm, custom, k-mount, lens, lists, option, options, pentax lens, pentax-m, slr lens, smc, smc pentax-m 50mm
Wanted - Acquired: SMC Pentax-FA 1:1.7 50mm or SMC Pentax-M 1:1.4 50mm (Aus) Pixley Sold Items 2 08-19-2010 05:56 PM
For Sale - Sold: Pentax SMC-M 28mm F2.8 and Pentax SMC-A 50mm F1.7 (non func A setting) (US) pxpaulx Sold Items 5 07-23-2010 10:38 PM
For Sale - Sold: SMC Pentax-F 35-70mm F3.5-4.5;SMC Pentax-A 50mm F2;SMC Pentax-DA L 18-55mm F3. TATA Sold Items 14 06-17-2010 04:05 PM
DPreview pentax 50mm f1.4 up today davebris33 Pentax SLR Lens Discussion 9 11-14-2008 09:50 AM
All times are GMT -7. The time now is 07:33 AM. | See also: NikonForums.com, part of our network of photo forums!
