About the long debate between Pentax 12-24 and Sigma 10-20 f4/5,6 ...
1-The Pentax seems better, but having a 17-70, how much value I'd get from only 5 mm extra lenght? So maybe the 10-20 would be better.
2-About the Sigma: there are opposite opinion, also between good review sites:
dpreview : Sigma 10-20mm F4-5.6 EX DC HSM Comparison to other wideangle zooms we've tested recently suggests the Sigma's class-leading days may be numbered. On APS-C, it simply can't match the biting central sharpness of the Tamron 10-24mm F3.5-4.5 Di-II in the 10-18mm range (for which, we suspect, users will mainly be buying this type of lens), and has more problematic distortion characteristics. However in a typical case of swings and roundabouts, the Sigma shows superior sharpness when shot wide open, and is better in the corners of the frame at all settings; it also has lower chromatic aberration, is better built and uses a superior focusing system."
while on
photozone "The Sigma AF 10-20mm f/4-5.6 EX DC showed an pretty impressive performance with a few bugs. The resolution characteristic is generally very good to excellent except in the extreme corners at 10mm which are a bit soft at large aperture settings. A weak aspect of the Sigma is very high vignetting at large apertures - to be fair this is relatively normal regarding the extreme ultra-wide focal-length range. The CA characteristic (color shadows at the image borders) is generally pretty good except in the extreme corners at 10mm. The build quality of the lens is very high and leaves nothing to be desired. All in all a good alternative to the native Pentax lens"
3-waiting for the upcoming Sigma 10-20 f/3.5 HSM
