05-26-2009, 09:08 PM   #1
Pentaxperson's Avatar
Budget Macro stuff...
Most of you know this already....I think.
I have a Several Macro lenses..but I decided to try something a little different this time...
This is a cool little cheap trick to get some Macro shots..
It works great for flowers, objects, etc...
It's the same principle as an extension tube. I know Tele's can be had for much less than tubes...and like I said it's if you happen to have a tele converter you don't use...and it's a good way to put it to good use.
It greatly reduces the minimum focusing distance by taking the rear of the lens farther away from the sensor/negative.
You will need
1. A Teleconverter (one you don't give a care about )
2. A lens!
Then you need to take out the magnification glass from the TC.
Connect it to a lens
Connect to camera and shoot!
Examples of the new minimum focusing distance and the sample:
I converted it to BW.
This is without the TC and the minimum focusing distance without TC modification.
Sample from standard lens without modified TC
If you happen to have a Macro lens this might not be to useful...or you could just make your current Macro have less of a MFD.
Lens used was a Sears M42 SCREW mount 28mm F 2.8 The lens is about 30 years old and the TC used is an OLD Vivitar 2x-1 also M42 Mount. I used an K mount adapter to mount on to my K20d.
This will work for any camera..
Oh... CAST:
Pentax *istDS2 taking pics of K20d
K20d doing the actual Macro heavy work
K10d being lazy.
05-26-2009, 09:31 PM   #2
res3567's Avatar
QuoteOriginally posted by Pentaxperson Quote
You will need
1. A Teleconverter (one you don't give a shit about )
2. A lens!
Oh... CAST:
K10d being lazy.
So in basically, thre farther the lens is from the sensor the greater the macro capability?
05-26-2009, 09:38 PM   #3
Marc Sabatella's Avatar
QuoteOriginally posted by res3567 Quote
Yes. Moving the lens further out allows it to focus more closely, which increases magnification. That's the whole idea of extension tubes.
05-26-2009, 10:33 PM   #4
res3567's Avatar
Ok. That being said, my Raynox should be here any day now.
How close were you able to focus with your SMC 135 f/3.5?
05-26-2009, 11:44 PM   #5
simons-photography's Avatar
so are exstension tubes a better way than magnification filters ?
05-27-2009, 12:28 AM   #6
RioRico's Avatar
QuoteOriginally posted by simons-photography Quote
Extension tubes don't introduce any more layers of glass between lens and subject. Mag 'filters' are really diopter lenses, ie two more glass surfaces to distort, refract, and reflect light. Raynox magnifiers are pretty handy and non-distorting, and don't cut down the available light. Tubes always exact a penalty - less light reaches the lens. So there's a trade-off: tubes or bellows or any other extension provides less light, thus longer exposures, thus more need for tripod. Vs magnifiers don't cut down the light, but can degrade the image more or less. These are just optical facts and can't be bypassed.
The other cheap macro trick is to get a reversal ring - most prime lenses are pretty sharp when reversed, and will only macro-focus. You'd have: CAMERA--REV.RING--REV.LENS--SUBJECT. But then you lose all auto aperture control and must try to focus while stopped down in order to get any DOF. Yet another trick is to add a reversed secondary prime to your main prime, via a step-ring, for CAMERA--MAIN.LENS--STEP.RING--REV.LENS--SUBJECT. There you keep aperture control, but it's the same as adding diopter/magnification filters/lenses, with the same image degradation.
Tubes or bellows are the cleanest way to go macro. A Raynox or diopter magnifier is the easiest-to-use way. A lens-reversal-ring is the cheapest way. A short prime with a short tube probably has the least drawbacks (but not a lot of magnification). All have their pros and cons. TANSTAAFL.
05-27-2009, 01:07 AM   #7
TANSTAAFL.
Gesundheit!
budget macro, distance, k-mount, k20d, lens, m42, macro, pentax lens, sample, slr lens, tc
which macro on a smaller budget screwedon Pentax SLR Lens Discussion 5 11-06-2010 07:19 AM
Macro shooting/lens on a BUDGET KxBlaze Pentax SLR Lens Discussion 12 04-09-2010 06:17 PM
Best budget macro lens? raver1414 Pentax SLR Lens Discussion 15 12-10-2009 12:50 PM
Macro options (on a budget) Zou Pentax SLR Lens Discussion 11 07-29-2008 12:06 AM
some macro stuff lodi781 Photo Critique 4 04-01-2008 08:20 AM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
