06-02-2009, 04:42 PM   #16
QuoteOriginally posted by Quicksand Quote
Grooves or dimples. An old Ricoh lens I have uses dimples that could probably be reproduced with the tip of a drill bit, while those grooves could probably be hacksawed. (Carefully!) I'm not sure which the Cosina uses.
As you can probably tell, I've been thinking about taking apart the mount end of my Cosina and adding the half-stops myself, but I'm wary of not putting it back together successfully. That's a common problem I have once I take things apart.
Set up a video camera and set the pieces aside in separate sections of a tray, in order (and tell the camera what you're doing the whole time).
And then let me know how hard it is to do the whole thing, since I'd be interested in replicating this if I manage to snag one in the future =)
06-02-2009, 05:51 PM   #17
I've found that getting the aperture ring off a MF prime isn't actually a major operation. You usually only have to screw off the back plate and you can leave the aperture lever in place so you're not actually messing with the insides of the lens.
Once you've got it off you should be able to dremel out a couple more grooves.
I think i'll still get an A lens.
06-02-2009, 08:38 PM   #18
Just1MoreDave's Avatar
QuoteOriginally posted by ILoveVerdi Quote
It's not that hard. Four screws for the mount. Disconnect a spring and lift off the part containing the aperture lever. Then lift off the aperture ring. Unlike the Pentax arrangement, this lens has the slots cut in the top of the rim of the aperture ring, not the inner side. The ring is then trapped between the mount and the lens barrel. The bearing isn't under pressure once you remove the mount so it won't spring off into space like on a Pentax lens.
Making new slots seems feasible. How depends on the tools you have. I just put it back together; too many other lenses apart right now.
06-03-2009, 06:27 AM   #19
vizjerei's Avatar
stopping down on a 1.2 lens?! for shame.
When I eventually procure one of these I plan on setting it to 1.2, leaving it there, and getting drunk off the bokeh.
Since I got my K50 f1.2 I haven't use my FA50 anymore.. so I did stop down when I use my 50/1.2
I remember it has half stop on my K 50/1.2. I would recommend the A 50/1.2 as it has 9 blades as K50/1.2 has 8, If you have the cash
K 50 f1.2
06-03-2009, 09:04 AM   #20
Digitalis's Avatar
be careful mate, you can get pretty wasted on the bokeh this lens can produce..
aperture, k-mount, lens, lenses, pentax lens, question, slr lens
50mm-ish portrait lens? MrCynical Pentax SLR Lens Discussion 34 05-10-2010 02:34 PM
If you could have only 2 lenses in the 50mm(ish) range, which two would you pick? Clinton Pentax SLR Lens Discussion 64 04-05-2010 09:49 PM
pentax tokina 28mm f2.8 pka r pka mount dcmsox2004 Pentax SLR Lens Discussion 13 03-16-2009 10:53 AM
For Sale - Sold: PKA mount roy Sold Items 8 02-23-2009 04:57 PM
All times are GMT -7. The time now is 12:17 AM. | See also: NikonForums.com, part of our network of photo forums!
