06-06-2009, 10:32 AM   #1
better 50/1,2
which is the sharp (assuming sharpness = resolution and contrast) pentax 50/1,2?
There are three types, aren't there?
I want to buy one and looking for the best one.
06-06-2009, 10:45 AM   #2
Wheatfield's Avatar
http://www.takinami.com/yoshihiko/photo/lens_test/pentax_normal.html
06-06-2009, 11:50 AM   #3
Thx, Wheatfield, very usefull.
It seems that I will have to live with the "A" fringes.
06-06-2009, 05:25 PM   #4
Digitalis's Avatar
unless you're like me and find a really good K 50mm f/1.2...
06-06-2009, 05:57 PM   #5
K-9
K-9's Avatar
3 types? There are more than that for Pentax K-mount:
Cosina 1.2 (58mm filter)
Cosina 1.2 (55mm filter)
Ricoh 1.2 (not sure which filter size this has)
Porst 1.2 (55mm filter)
Tomioka 1.2 (58mm filter)
Pentax 1.2
Pentax A 1.2
The most desirable and expensive has always been the Pentax-A. I also assume that this means it's the sharpest of all listed here.
06-06-2009, 06:32 PM   #6
Digitalis's Avatar
QuoteOriginally posted by K-9 Quote
no that's because it maintains metering functionality which is something that the Pentax K 50mm f/1.2 doesn't. but even this shortcoming can be bypassed to an extent.
both pentax 50mm f/1.2 lenses have similar optical construction, thought they have a different number of aperture blades eight Vs Nine which makes an almost trivial difference between the two. I prefer the construction quality of the Pentax K 50mm f/1.2....I don't like the build of a lot of the A series lenses, it's just a matter of personal preference.
06-07-2009, 05:57 AM   #7
rparmar's Avatar
The smc Pentax 50mm f/1.2 works for me. A German test I saw had it beating all competitors, including Nikkor, Canon FD, Minolta MD Rokkor, Olympus Zuiko and Leitz Noctilux. Though the Nikon lens came closest.
A couple of shots.
daffodil
toy bear suicide
06-07-2009, 12:13 PM   #8
A Proud PENTAXER !!!
fwcetus's Avatar
[or] SMC Pentax Resolution Test Results
06-07-2009, 03:20 PM   #9
Duplo's Avatar
QuoteOriginally posted by rparmar Quote
Out of curiosity, whoch nikkor are you refering to the 50/1.2 AI, 50/1.2 AIS, 55/1.2 AI or the 58/1.2 noct?
There is something about those classic f1.2 50ies though, such a beautiful rendering from them and very different from the modern f1.4 and slower variants.
06-07-2009, 04:38 PM   #10
rparmar's Avatar
QuoteOriginally posted by Duplo Quote
I found the reference. Here is the full chart. Lower numbers are better.
Code:
LENS TESTED ----------------f/1.2 ----f/2.8 ------f/5.6 ----Average
Pentax SMC 50mm f/1.2 --------101 -------77 ---------50 --------228
Nikon Nikkor 50mm f/1.2 ------116 -------73 ---------49 --------238
Canon FD 55mm f/1.2 ----------117 -------82 ---------45 --------244
Minolta MD Rokkor 50mm f/1.2 -117 -------75 ---------54 --------246
Canon FD 55mm AL f/1.2 -------117 -------84 ---------51 --------252
Yashica ML 55mm f/1.2 --------124 -------90 ---------51 --------265
Olympus Zuiko 55mm f/1.2 -----125 -------90 ---------60 --------275
Nicon Noct-Nikkor 58mm f/1.2 -158 ------107 ---------52 --------317
Leitz Noctilux 50mm f/1.0 ----152 -------97 ---------67 --------316
Konica Hexar 57mm f/1.2 ------166 ------129 ---------58 --------353
Found in a Manual Focus Forum thread.
06-07-2009, 05:01 PM   #11
Duplo's Avatar
Code:
Strange results... the NoctNikkor is by a lot of people described as perhaps the most impressive 50ish mm lens ever made, a lens made and optimised for wide open performance... it is however also know for exhibiting extreme field curvature.
Bjørn Rørslett ha a very interesting comment on it here:
Normal Lenses For Nikon 'F' Mount
at the bottom of the page.
06-07-2009, 05:25 PM   #12
Digitalis's Avatar
The noct nikkor is very good lens, though it isn't great when it is stopped down past f/4. The Lieca noctilux shares this characteristic...Canon did produce a 50mm f/1.0 fir their EF SLR cameras but optically is was nothing to write home about.
the Noct nikkor was designed for astrophotgraphy which is why It had an aspherical element to eliminate the effect of coma in the extrememe edges of the image field.
The noct nikkor has achieved cult status amongst nikon Photographers because it's the only mass produced f/1.2 lens nikkor ever made for the F mount. buying one these days is an expensive affair because they are quite rare, but from what I have heard even the pentax 50mm f/1.2 (both K and A variants) are considered rare. There are a few variants of the noct nikkor, but the optical properties of the lens remains more or less unchanged.
06-07-2009, 05:50 PM   #13
Duplo's Avatar
True, the noct, is supposed to reach its peak in the f1.4 to f2.8 range
actually there is a few 50/1.2 nikkors produced.
the 50/1.2 AIS, which is still in production.
the 50/1.2 AI, which is not and the 55/1.2 pre AI which is out of production too.
The noct mainly received its cult status from being produced for wide open or near wide open performance only IIRC.
06-08-2009, 08:36 AM   #14
rparmar's Avatar
Anyone who knows German might be able to make sense of this chart.
06-08-2009, 10:43 AM   #15
GeneV's Avatar
I speak German, but it takes a good deal of effort to figure out that chart. It appears that the lower number of points means the lens is better.
k-mount, pentax lens, slr lens
All times are GMT -7. The time now is 10:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
