04-26-2007, 04:31 AM   #1
Help with possible 50 1.7 A issue
Hello everyone,
I just picked up a 50 1.7 A lens to use on my K10D. I put it on last night for the first time, set the aperture ring to A, set it to P mode and took a few shots. Every thing appears to work right except the largest aperture it displays is f2.0. Try as I might it won't go to f1.7. I've tried removing the lens and checking the stop down lever, manually rotating through all the apertures, and resetting it to A several times. The blades feel like the move freely enough. Still the same thing, f2.0 nothing lower. Am I missing something?
thanks
Dave
04-26-2007, 05:50 AM   #2
You just picked up a used lens that is somehwere between 18 and 23 years old. You don't know when it was in regular use. The contacts may be dirty or oxided. (I assume your camera works just fine with all other "A" lenses you have.)
Clean the contacts on the lens by wiping them carefully. Also touch the cameras contacts with the cleaning sheet and try again. Then mount the lens and set the camera to the Av mode. Turn the wheel and see what aperture values you can choose. Maybe it helps or not. If not I don't know what it can be.
04-26-2007, 06:10 AM   #3
I don't think there are any contacts on the lens, as it is full manual. Right? I don't think I remember seeing any on there. I was under the impression the camera body stopped the lens down via the little protruding lever on the lens mount. The only other lens I have is the kit lens, and it works fine. I didn't try Av yet, not sure why. I did try M and there was no difference.
Dave
04-26-2007, 07:19 AM   #4
Mike Cash's Avatar
If you have an "A" setting on your aperture ring, there are contacts on the lens. They're necessary to provide a route of communication between your lens and camera body regarding aperture. It's the same route the "2.0" info showing up in your viewfinder travelled at some point.
They'll just look like little dots. They match up with the small contacts around the periphery of your camera body's lens mount, down near the release button.
04-26-2007, 07:19 AM   #5
Why not have a look at the lens? I think there is a contact on it. But what it does? I don't know. Maybe it reports max aperture opening.
As it is an A lens you should try Av mode. The M mode is after all pretty compromised by the camera's inability to read the light stopped down.
04-26-2007, 07:25 AM   #6
Thanks guys, I'll check it out. Unfortunately I'm at work right now, so no access to the lens.
Thanks agin,
Dave
04-26-2007, 05:23 PM   #7
Buddha Jones's Avatar
You mean, you dont take your camera to work with you?
04-27-2007, 04:58 AM   #8
I wish Well, I tried to clean the contacts last night, no luck. Still the same, P mode or Av, lowest displayed aperture is f2.0. Kind of at a loss, thinking about just contacting the seller about returning it.
dave
04-27-2007, 06:09 AM   #9
Denis's Avatar
I would go in camera settings and change aperture setting steps from 1/2 to 1/3. It might be that when it gets to f2.0 it can only jump to f1.5 which is not available.
04-27-2007, 06:17 AM   #10
I'm sorry to hear that Dave. Denis idea is worth a try though. I seem to remember that the A50/1.7 went to f/1.7 on my DS when set to half stops in the menu but that might have changed with the K10D. (And it is after all half a stop from f/2 to f/1.7.)
Denis' suggestion is probbaly the only thing left to try.
04-27-2007, 07:09 AM   #11
Yeah I thought that might be it too, unfortunately that was actually one of the first things I tried. I may try one other thing. I'm giving my wife her anniversary present of a (new to her) Pentax DS this weekend. I might try to check it on there to see if acts the same. On a side note, with all this checking out of the camera, I noticed I appear to have front focus issues, so I'm going to hav eto check that out further
Dave
04-27-2007, 06:17 PM   #12
Arjay Bee's Avatar
I know this is really obvious but you did activate the custom setting to allow for manual aperture ring eh?
04-28-2007, 01:56 AM   #13
Mike Cash's Avatar
QuoteOriginally posted by Buddha Jones Quote
Mine sits at my elbow, like a faithful hound, while I am at work.
aperture, f2.0, k-mount, lens, pentax lens, slr lens
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Possible Kx Issue? UnknownVT Pentax DSLR Discussion 21 11-29-2009 06:46 PM
A printer issue, or a processing issue... FHPhotographer Digital Processing, Software, and Printing 0 10-03-2008 12:13 PM
WB Issue paulsoucy Pentax DSLR Discussion 1 03-14-2008 12:44 PM
All times are GMT -7. The time now is 03:50 AM. | See also: NikonForums.com, part of our network of photo forums!
