06-07-2009, 06:54 PM   #1
alexeyga's Avatar
Is it me or there's something wrong with my K300?
Got to do some real shooting with my recently acquired K300/4 and i've just noticed that a few pics shot wide open came out... well... weired... somewhat toy-ish... which can usually be seen on T/S lenses...
Click for the full res. pic
Never mind the CA... I still need to get a really good haze filter... or/and a polarizer...
So?
06-07-2009, 06:59 PM   #2
Damn Brit
Guest
I see what you mean but I don't have an answer.
06-07-2009, 07:57 PM   #3
Long focal length, very shallow depth of field, high contrast, all hallmarks T/S effect.
See this.
06-07-2009, 10:10 PM   #4
i dont see a problem?
do you mean the front and backgrounds are out of focus? because that is possible to do
I forget the conditions required but it was a photography assignment for my sister once.
I originally thought you could only do that with macro.
06-08-2009, 04:00 AM   #5
It's the lens, I get a similar effect, not as bad if I use the 300 wide open. Since the DOF is so thin I usually stop down a bit. Also as song hm has said the high contrast makes it more prominant. Try dropping contrast a bit in PP. The shot doesn't look over sharpened, but since sharpening is a contrast function, I'd go real easy on the sharpening too, if there was any used.
NaCl(best solution is to stop down a bit)H2O
06-08-2009, 04:53 AM   #6
Is that your first 300 f/4 ?
DOF2
06-08-2009, 12:53 PM   #7
alexeyga's Avatar
QuoteOriginally posted by asdf Quote
DOF2
Yep.... it's my first 300mm at all... And i'm rather surprised with the outcome...
06-08-2009, 01:08 PM   #8
Looks like a normal picture with a 300, wide open. or near wide open. Nothing strange!
You see the same tight DOF here on this picture taken with my DA*300 wide open.
PENTAX K10D  Photo
06-08-2009, 01:24 PM   #9
Lowell Goudge's Avatar
one thing I find difficult from time to time, with the 300 F4 is focus confirmation through the camera body. Sometimes, if you rely on this, and your subject has detail rising up to the focus point (i.e. like your shot and the water in front of the subject) you can find yourself getting focus confirmation due to vertical vibration, on the wrong subject,
This is especially true when using any long lens in AF mode also
06-08-2009, 03:44 PM   #10
Marc Sabatella's Avatar
Just curious - what is it exactly we are supposed to be looking for? As others have said, it looks like a pretty ordinary 300mm shot to me, and I'm having a hard to seeing whatever it is you are referring to as akin to what you'd see on a "T/S" ("tilt/shift?") lens. Something to do with distortion? When you say "toy-ish", I at first thought you meant the quality of the the lens, but now I'm thinking maybe you mean there is a sense in which the perspective of the shot somehow seems "off" in a way that the *surfer* look like a toy. In which case, I'd say I do see a little of that, but I would imagine that's inherent the perspective inherent at this the distance and magnification.
Actually the issue of what visual cues create the sense of, say, a picture of a model train *looking* like a model versus a real train, and vice versa, is one I've often been curious about, but never really thought through.
06-08-2009, 03:55 PM   #11
alexeyga's Avatar
Marc, just look at the water and splashes... It looks as if the dude is actually surfing in a bathtub rather than a lake.... In other words there's a certain sense of disproportionality or fakeness...
This one here, was shot at f/11... and looks much more natural to me...
06-08-2009, 03:58 PM   #12
alexeyga's Avatar
Actually so far the one thing i've enjoyed about this lens is the fact that it's the MF one... And i'm mostly shooting focused down to infinity (or just shy of it) anyways... Need more practice and more windy days... though when it's blowing, i'm with these guys out there....
Anyways... i think it's just the right combination of things.... aperture wide open+shotting almost facing the sun+highly contrasted subject... just to say that I was somewhat puzzled with some pics...
06-08-2009, 07:26 PM   #13
F16
As you mention, it's just a combination of things at play - shallow DOF even for a distance subject, lighting conditions, plainly visible background and foreground subjects (the water), and the bokeh characteristics of the lens all make for an unusual look.
06-08-2009, 08:44 PM   #14
QuoteOriginally posted by alexeyga Quote
OK, like I said, I do sort of see that, but as far as I can tell, that really *is* the proper perspective at that distance and magnification. It's jutst that we never normally see this object from that distance that larger - with the naked eye, it's much smaller, giving us different visual cues.
The other shot is a different scene. Which brings me back to my musings about what specifically *causes* the illusion I think we are both seeing.
06-09-2009, 08:54 AM   #15
reeftool's Avatar
The second photo with the 2 windsurfers gives some proportion to the photo plus the background is nicer at f11. Your shot is focused good, it's just the narrow DOF that gives it that look. I would crop it tighter and maybe some adjustments in PP.
k-mount, pentax lens, slr lens
OK i have to be doing something wrong! 5teve Pentax DSLR Discussion 22 06-02-2009 03:14 AM
What have i done wrong.. Squier Troubleshooting and Beginner Help 11 05-28-2009 07:20 AM
What am I doing wrong here ? holdgaj Troubleshooting and Beginner Help 9 04-30-2009 10:40 PM
Kumaon Himalayan Avifauna with K300/4 hrishi Post Your Photos! 5 07-10-2008 09:00 AM
New accessory for my K300/4??? wjwncpro Pentax DSLR Discussion 5 04-19-2007 06:51 PM
All times are GMT -7. The time now is 03:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
