Originally posted by jerrymouse I'm not sure the 2x TC looks similarly inside, but it's worth a shot.
Slightly different from the one you have.
Thanks for your help.
I’ve disassembled it and the connection between the front/rear mount is provided by pins mounted on each side of the springs, thus making a straightforward, direct pin to pin connection between the front/rear mount (no "L" shaped lugs to cling the springs on).
I can’t see why the electronic connection isn’t working; I’m going to clean all the pins and springs with some contact cleaning solution and see what happens; it´s fine to use manual aperture on the lens (actually, sometimes works better than the A set) but I’m going to try to fix it anyway.
BTW, there are two levers on the TC; one of the levers is attached and constrained to a position by a spring; the other is not and it runs freely, up and down, on is course. On yours second photo of the TC parts, we can see, on the TC front mount, the small flange with its half rounded shape (the diaphragm lever that operates DOF preview?); it’s the lever that can be operated by the rectangular flange on the rear mount. Is this normal or should it be also constrained to a position? I would appreciate if you could give me some info here.
Again, many thanks for your help.
MB
