06-25-2009, 10:34 AM   #16
Picturs of the baby
On the wifes K20.
And now of to learn about product shots ;-)
06-25-2009, 11:34 AM   #17
Ben_Edict's Avatar
QuoteOriginally posted by thomascdk Quote
Your product shots are not too bad (no wonder with this modell). But what lens did you use? Shows quite noticeable CAs, especially in shots no. 1 and no. 3. Congratulations anyway. I hope you have lots of opportunities to use this lens.
Ben
06-25-2009, 11:45 AM   #18
QuoteOriginally posted by Ben_Edict Quote
Ben
Thanks! All shots are with the A50/1.4 in very low light. The first three is wide open at 1/180. That probably explains it. I sort of did go for the shallow DoF. The last one is f11.
I'm sure I'm going to be using this a lot. If not for anything else than the joy of handling it...
06-25-2009, 01:02 PM   #19
wtlwdwgn's Avatar
I would say that you got a very good deal considering the two on eekBay right now. There's an A 15mm f/3.5 for $1600 USD and a K 15mm f/3.5 for $945 USD. Both appear to be in excellent shape. That A is about 3X more expensive than a new 15mm Limited!
06-25-2009, 01:49 PM   #20
kristoffon's Avatar
That lens really made me drool. Congratulations!
06-25-2009, 11:06 PM   #21
Sean Nelson's Avatar
The metal Asahi Pentax lens cap alone is pure joy.
Guard that cap with your life! It slips off as easily as it slips on, and I lost mine many, many years ago. If you loose it, you'll find that it's basically impossible to replace.
06-26-2009, 05:29 AM   #22
QuoteOriginally posted by Sean Nelson Quote
Here I'm lucky with the lens' only fault. There's a dent on the hood, that makes the cap fit very tightly. But I will guard it. It's an object of beauty in it self.
k-mount, pentax lens, slr lens
K7 Again! Should go for it now? Dilemma! jpzk Pentax DSLR Discussion 21 11-30-2009 07:44 PM
Dilemma: Pentax K-7 or Pentax K20d+wide angle lens? skawi Pentax DSLR Discussion 12 07-10-2009 07:59 AM
Wide Zoom or Wide Prime....Planning Ahead joelovotti Pentax SLR Lens Discussion 25 12-21-2008 12:46 PM
Dilemma Substitute Pentax DSLR Discussion 12 08-25-2008 06:51 PM
Wide angle dilemma dsimon Pentax SLR Lens Discussion 5 11-29-2007 08:49 AM
All times are GMT -7. The time now is 06:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
