06-13-2009, 12:25 AM   #1
Pentax fa 80-320 4.5-5.6 - can't infinity focus?
Hi All, I'm hoping one of you knowledgeable types can help me find a clue...
I just received the above-mentioned lens, and was futzing around tonight, taking shots of the moon. Interestingly, I cannot focus (auto or manual) this lens on the 2/3 full moon. My DA 50-200 lens does just fine, and my old Tamron 70-300 also had no problems getting a sharp moon shot, on my old K100D.
I'm currently using a K2000 body.
Anyone with any thoughts on this? Or is it just one of those things, and I'm SOL?
Thanks for any input!
06-13-2009, 05:06 AM   #2
wwwmorrell's Avatar
You do have the A setting on the lens locked in ??????
06-13-2009, 09:37 AM   #3
QuoteOriginally posted by wwwmorrell Quote
Thank you for the response. Yes, the A setting was locked in.
I failed to mention that I am able to MF on the moon at about 80mm, although AF won't work.
A few quick tests this morning, I can AF on a tree about 200 ft away, but not on a variety of subjects beyond that.
All of this is at 320mm.
06-13-2009, 11:36 AM   #4
Just1MoreDave's Avatar
It can be adjusted, but I can't find a good enough photo of the front of the lens to say exactly how. From the optical diagram, it looks like the front three elements form one lens group, and I think that group moves in and out to adjust infinity focus. I've done this on a couple of later zooms and that group was held in by threaded rings with slots in them for a spanner wrench. The outermost slots, if there are concentric rings. The rings thread into the filter threads. Loosen the ring, mount the lens on a camera, and try to focus on a distant object at 320mm. Then rotate the group a little and try again. You should check at 80mm before tightening everything; the middle range will be fine as long as both ends work.. AF logic is supposed to be happier if the lens can go past infinity slightly, so I would adjust for that. The group/ring may already be loose, causing your issue. Unless the ring is gorilla-tight, this should be a simple fix.
06-13-2009, 04:31 PM   #5
QuoteOriginally posted by Just1MoreDave Quote
Thank you for that wonderful info! Since my lens is still within the return period, I'm going to send it back, though.
k-mount, lens, moon, pentax fa, pentax lens, slr lens
My Pentax SMC-A 70-210/4 won't focus to infinity, what to do? pasipasi Pentax SLR Lens Discussion 5 04-15-2014 11:22 AM
Pentax K20D & M42 Lenses Infinity Focus Question kopimorning Pentax SLR Lens Discussion 4 07-17-2010 05:56 PM
Samyang 800mm + T2 -> Pentax infinity focus problem k7bb Troubleshooting and Beginner Help 24 06-29-2010 10:37 AM
Pentax 85mm f/2 -- does yours focus past infinity? deadwolfbones Pentax SLR Lens Discussion 10 04-30-2010 10:32 PM
For Sale - Sold: Genuine Pentax M42 adapter - allows infinity focus Finn Sold Items 1 04-05-2007 07:22 PM
All times are GMT -7. The time now is 03:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
