06-17-2009, 12:06 PM   #1
bwield's Avatar
Vivitar 100mm 2.8 need fixing....
Well I sold this lens in the marketplace, and it seems that it must have been damaged in transit.
The problem?
Simply that it wont Stop Down.
When on the A setting the camera cannot make it stop down, and when I manually change the aperture nothing happens.
There is still the soft clicking when manually changing the F stop, but the blades do not close.
Is this something that can POSSIBLY be fixed easily?
06-17-2009, 01:08 PM   #2
Just1MoreDave's Avatar
I think this is a close relative of the Kiron 105mm f2.8 macro, right? Hope so, otherwise my advice is meaningless. The Kiron has two long arms that extend into the lens and move the aperture. They have to be long because the lens extends so much. Here's a photo:
This part is very easy to remove. Take out the four screws on the ring just above the aperture ring (where the PK/A label is in my photo) and it slides out. You may have to disengage a tab that fits into the long slot in one arm. The rear lens group is also easily removed at this point, so you can see the aperture right there.
The likeliest possibility is oil on the blades has stuck them wide open. The focus grease might have vaporized and gotten onto the blades in transit if the lens was subject to high temperatures. Otherwise, I don't know. One lever is moved by the stop-down lever in the camera and the other is moved by the aperture ring. Each lever controls distinctly different parts of the aperture mechanism.
k-mount, pentax lens, slr lens, vivitar 100mm
For Sale - Sold: Vivitar 100mm f2.8 Macro (US) yyyzzz Sold Items 20 11-29-2010 05:05 PM
Vivitar PK-A 100mm F2.8 lens CrazyNuts Pentax SLR Lens Discussion 14 02-23-2010 05:21 PM
For Sale - Sold: Vivitar 100mm f/2.8 Macro 1:1 Manual Focus PKA OR Vivitar Series 1 Macro yyyzzz Sold Items 6 10-22-2009 05:18 AM
For Sale - Sold: Vivitar 100mm f/2.8 Macro 1:1 Manual Focus PKA Same optics as Vivitar Series jjdgti Sold Items 10 10-05-2009 05:19 AM
Vivitar 100mm f/2.8, anyone have this? jsherman999 Pentax SLR Lens Discussion 13 01-12-2009 07:37 AM
All times are GMT -7. The time now is 03:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
