06-23-2009, 11:42 PM   #1
Deimo's Avatar
Use of Aperture-Ring 43mm/1.9 -> no aperture data
When i use the aperture-ring (camera is set to: aperture ring-> allowed)
I get no Data for the aperture on my K10D.
Example:
- Camera is set to "M",
- Aperture ring to Aperture 8,
- after pressing green Button i can here the camera meter, and i can see the suggested shutter speed e.g. 1/60.
- problem/question: the aperture display is "F ---" (before and after making the picture, exif also no data for aperture)
is this normal?
06-24-2009, 01:02 AM   #2
ftpaddict's Avatar
Yes. Don't do that. Keep the aperture on "A" and control the diaphragm with your e-dial.
06-24-2009, 01:04 AM   #3
creampuff's Avatar
Set the aperture ring to A and select the aperture via the camera's e-dial.
There is no reason to set the aperture manually on the aperture ring if your lens has the A setting like the FA 43mm Limited.
Read the camera and lens manual...
06-24-2009, 11:15 AM   #4
Deimo's Avatar
thank you for the answers.
i know, that is is kinda dumb to to that.
the reason was: i gonna buy an old lense next weekend, and i wanted to test around...
but i still wonder, that there was no data... i hope i will be there when i buy the smc-a50/1.2, but this of course also has the a setting
06-24-2009, 11:18 AM   #5
Nesster's Avatar
As long as you have the smc-a on the a setting you get aperture, but will not get focal length.
06-24-2009, 02:51 PM   #6
Marc Sabatella's Avatar
Any time you use the aperture ring on any lens, you won't get aperture info in the viewfinder or in the EXIF. That's the whole reason there is a sticky thread in the beginner forum on how to use manual lenses with a DSLR - you need to use stop-down metering via the green button (or a different button, depending on the camera model).
06-24-2009, 03:10 PM   #7
Deimo's Avatar
so if i have the smc-a mounted at my k10d, and the aperture ring is set to "A", then there has to be the aperture (and not the "F---") . If not, there is something wrong with the lens/camera.
is that right?
this i did not find in the "beginners article"
06-24-2009, 03:25 PM   #8
Yes, there is something wrong with the lens. Sometimes one of the contacts between lens and body is intermittent. Try cleaning the contacts.
QuoteOriginally posted by Deimo Quote
is that right?
aperture, camera, data, k-mount, pentax lens, slr lens
Will KR mount xnsmit aperture data? gsrokmix Pentax SLR Lens Discussion 6 04-02-2010 01:36 PM
Aperture ring frozen. glsmith Pentax SLR Lens Discussion 2 02-19-2010 08:04 AM
Edit Aperture Data In EXIF?? VIXIV Digital Processing, Software, and Printing 3 02-19-2010 02:29 AM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
Can the Aperture ring? kshapero Pentax SLR Lens Discussion 5 10-28-2007 06:25 AM
All times are GMT -7. The time now is 10:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
