06-25-2009, 09:18 PM   #1
pacerr's Avatar
Reversed lens macros
Just a note to encourage those that haven't played with reversed lenses (yet).
It's REALLY easy to try this. The only special equipment you need are two opposed thumbs.
- Grab any 35~85mm lens
- Set focus to infinity
- Set aperture to max (or not, if you want a little DOF)
- Hold the reversed lens to the camera body by hand
- Get REALLY close to the subject - inches
But watch that exposed glass! At one time I was using reversed lenses to record small component failures so I reamed the center out of a rear lens cap to provide a protective hood. You're close enough that you can use your 'pinky finger' as a feeler gauge outside the field of view also.
I've found 35-85mm lenses offer the most useful range. A Schneider-Kreuznach Xenar f:2.8/45mm salvaged from a trashed Kodak RF and hot glued to a old Spotmatic body worked well in the field without risking anything expensive, although I preferred a Super Tak 55/1.8 for the greater FOV.
In the office, we made sort of a copy stand out of a U-shaped wire refrigerator rack and used a ream of type writer paper as a variable-focus rack to position the items with better precision and stability than a focus rail - just add or remove pages to raise or lower the target.
"Yeah, two more pages an' a carbon copy sheet ought 'a be perfect, Joe."
H2
06-25-2009, 10:01 PM   #2
Canada_Rockies's Avatar
I went a little higher tech for my uber-macro trials. SMC-P 28/3.5 reversed with a 49>52 step up ring on a 52mm reverse adaptor on the KX/ SF-1. Gave about 2.1X on film.
06-26-2009, 02:03 AM   #3
David's Avatar
QuoteOriginally posted by pacerr Quote
H2
Yes, reversing is the quick and easy way to good macros, I posted some 43mm Ltd reverser K10D shots a while ago here FA 43mm Ltd Reversed Photos
Tried the 77mm Ltd and didn't get the same results
David
06-26-2009, 07:22 PM   #4
QuoteOriginally posted by David Quote
David
David, the wider the lens, the more magnification. 1:1 comes in around 55 mm reversed. 28mm is 2X. your 77 would come in at about 0.7X if my mental math is correct. 55/77 = 0.71X
06-26-2009, 07:32 PM   #5
so I suppose the trick is focusing with a third hand? lol
I must try this out soon.
thanks for the info OP
06-26-2009, 07:35 PM   #6
QuoteOriginally posted by Niki Quote
Focusing is disabled. The back of the lens will be at the lens to film/sensor distance from the subject when the subject is in focus. The focusing ring moves the lens body back and forth. You can get more light on the subject at infinity focus.
06-26-2009, 08:10 PM   #7
pacerr's Avatar
Focus by moving the entire camera back and forth. Once you get close enough to even BE in focus there won't be a quarter of an inch of movement -- or DOF either for that matter.
But that third hand could be useful to hold the spider you wanted to shoot anyway.
Remember -- this was just to get you hooked on lens reversal so you'd buy a reverse adapter which would stimulate the economy which would save Pentax so you could continue to stroke your LBA.
H2
body, copy, field, focus, k-mount, lens, lenses, pages, pentax lens, rack, slr lens
Reversed lens image circle? newarts Pentax SLR Lens Discussion 3 02-11-2010 08:37 AM
Macros with a reversed zoom lens newarts Pentax DSLR Discussion 3 01-05-2010 08:26 PM
Reversed 50mm Macros dreyes Post Your Photos! 1 06-10-2009 12:34 PM
Shots with a Reversed Lens sjl7678 Post Your Photos! 4 11-09-2007 11:06 PM
First reversed lens macros gratefulbruce Post Your Photos! 5 04-15-2007 06:09 PM
All times are GMT -7. The time now is 08:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
