06-26-2009, 01:42 PM   #1
cleaning the body of a lens
I was wondering if there is a way to clean a lens that has scratches on the body (not the glass)
Thanks
06-26-2009, 04:07 PM   #2
what do you guys think about that?
Paint, Flat Black Touch Up Pen - Part #: 15102-F
06-26-2009, 04:49 PM   #3
mickeyobe's Avatar
QuoteOriginally posted by redpigeons Quote
The paint on your lens might not be flat (or matte). It could be gloss or semi gloss.
Use a very, very fine sable or squirrel brush or even a pin.
Dilute the paint considerably so that it flows readily. It is best to put on several thin coats to bring the paint to the same level as the original finish.
For very tiny touch ups you could use a fine felt marker pen. However, I have yet to see a truly black marker. They usually have a red or purple tint which becomes noticable on larger touch ups.
Mickey
06-26-2009, 09:03 PM   #4
I have used paint pens similar to this. The key is to apply the paint over the scratch and quickly wipe the excess away leaving only the paint in the scratch.
You can also get white, red, green, tan, and other colors appropriate for touching up embossed lettering. I have a XR Rikenon that lost many of its numbers as I was removing tobacco residue from the barrel. The white paint pen did a great job of filling in the embossing such that you cannot even tell that the numbers had been redone.
P.S. You might want to test on an unexposed area to make sure that the paints are compatible. The thinner components in some paints may damage other paints.
P.P.S. I was told about the paint pen by the camera repair guy. I suspect that they use them as part of the clean-up process for used lenses they are preparing for sale.
P.P.P.S. You might also want to try the ultra-fine tip black Sharpie pen.
06-27-2009, 03:57 AM   #5
Arjay Bee's Avatar
Related to this issue is what product can you use to freshen up the rubber grips on the focussing rings? I have a build up of whitish powder, (dried sweat, finger tip skin, salt spray?)can I use that silicon based stuff used for rejuvenating plastic and vinyl car interiors?
06-27-2009, 06:37 PM   #6
For that I'd just use a q-tip with water on it and the dab off the excess water with a paper towel. It's what I've done in the past. I prefer to just do it the simplest way possible.
QuoteOriginally posted by Arjay Bee Quote
06-28-2009, 06:01 AM   #7
Arjay Bee's Avatar
Thanks Votesh - no harm done for this method - will see if it moves the gunk and let you know.
body, k-mount, lens, pentax lens, slr lens
Lens cleaning oldphil Troubleshooting and Beginner Help 5 05-16-2010 03:58 PM
Lens cleaning - Help! dycz Pentax SLR Lens Discussion 6 09-27-2009 09:38 PM
Lens Cleaning Fl_Gulfer Pentax SLR Lens Discussion 9 09-17-2008 02:22 AM
lens cleaning enrod666 Photographic Technique 5 06-14-2008 02:14 AM
lens cleaning Bob83 Pentax SLR Lens Discussion 5 01-17-2008 08:50 AM
All times are GMT -7. The time now is 12:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
