06-28-2009, 01:09 PM   #1
rparmar's Avatar
Better hood for DA12-24?
Does anyone have a line on a tried and true hood for the DA12-24mm lens? I am not sold on the plastic petal model that comes with the lens. Firstly because it doesn't seem strong enough and secondly because it doesn't protect so well from flare coming in the side of the lens.
06-28-2009, 01:17 PM   #2
Marc Langille's Avatar
Robin, I have the 12-24 but it's often with a CPL on it, since I am using it in bright lighting conditions handheld or landscape w/tripod otherwise.
Is your shooting technique or lighting options precluding using a CPL? Works quite well for cutting down on lens flare.
Regards,
Marc
06-28-2009, 08:02 PM   #3
rparmar's Avatar
QuoteOriginally posted by Marc Langille Quote
I actually have a 77mm CPL, since I was smart enough (for once) to buy this size and use stop-down rings with previous lenses. Although in fact changing those rings was a pain in the butt. Now I have such a large diameter lens it might come in handy.
But...
How the heck do you adjust it? The hood does not have the handy finger window that all the other Pentax petal hoods do.
06-28-2009, 08:07 PM   #4
rparmar's Avatar
Or do you mean you use a CPL and no hood? Not sure I'd do that, since it exposes the CPL to harm, and that sucker is worth money!
06-28-2009, 08:10 PM   #5
No sir - both are on the lens. It's not that bad to turn it with the hood on, since it's not very deep... just practice...
06-28-2009, 08:17 PM   #6
rparmar's Avatar
My B+W doesn't turn too easily. So this will indeed require practice!
I just tried a wide angle rubber hood pressed all the way back and it caused vignetting at 12mm. I couldn't figure that out, since it doesn't extend nearly as far as the stock hood.
Then the reason for the petal shape hit me across the head. I never thought about this before but.... rectangular aspect ratio. Doh! Now I get it.
06-28-2009, 08:23 PM   #7
My Tiffen CPL turns like a gem, no worries there.
You'll need the thin CPL version to avoid vignetting at 12mm. I rarely go below 14mm, but I can correct it in PP if needed.
06-28-2009, 08:58 PM   #8
Andi Lo's Avatar
I actually have a hard time turning the B&W filter properly too (67mm f-pro)... it feels like there's some kind of friction when turning it. After I dropped it it's much worse :ugh: but that's totally my own dumb fault. Luckily I'm only using it for the Tamron 28-75 so putting another broken CPL filter frame behind it isn't causing vignetting, but one day I'll have to get another one once I own an ultrawide... If I can afford a Pentax full frame I'll be able to afford another CPL anyway
06-29-2009, 02:53 AM   #9
rparmar's Avatar
I think I'm back to square one here. I don't really want to block a stop of light with the CPL. Maybe I'll invest in a plain old UV filter someday. Or find a metal petal hood.
Anyone test one of these eBay metal hoods for vignetting?
06-29-2009, 03:58 AM   #10
On my 12-24, I use the lens hood that came with my 14-2.8. It does have the window for the polarizer, and it makes only one hood to carry.
06-29-2009, 04:40 AM   #11
Ash
Community Manager
Ash's Avatar
My CPL is easy to rotate too without the need for the hood window.
I did try to fit a DA 14's hood with the window on my 12-24 and it just wouldn't secure on - looked like a different thread on the lens. Don't know how you made yours happen, Yves.
06-29-2009, 07:52 AM   #12
I borrowed my friend's 12-24 once and did not experience any flare even when I shoot direct into a bright burning hot sun
I only had the original hood and a Hoya Pro1 Digital Filter Protector on
At that very moment, I remembered asking myself: How they ever do that
06-30-2009, 06:30 AM   #13
I used an Xacto to "shave" the flanges on the filter a little . You have to be careful, because if you remove too much, it doesn't fit on the 12-24 anymore. After the "surgery", there is not too much "meat" holding the hood on the 14, so you have to be careful when installing it.
hood, k-mount, lens, pentax lens, slr lens
DA 15, DA12-24, DA*16-50 Comparison Images SCGushue Pentax SLR Lens Discussion 6 04-26-2009 11:49 AM
Polarizer for DA12-24 AndrewShirley Pentax SLR Lens Discussion 3 02-17-2009 09:30 PM
Playing with the DA12-24/4 heatherslightbox Post Your Photos! 0 09-17-2008 06:02 PM
I got a DA12-24 f4 Lance B Pentax SLR Lens Discussion 43 08-20-2008 10:09 AM
Sigma 10-20 or DA12-24? heatherslightbox Pentax SLR Lens Discussion 16 07-13-2008 05:21 PM
All times are GMT -7. The time now is 03:18 PM. | See also: NikonForums.com, part of our network of photo forums!
