06-30-2009, 07:53 AM   #1
Which lens (without using flash) for indoor use?
I have the K100D body (really enjoy the camera) and the standard kit lens (18-55?) which I use for indoor use, but will have to use the flash if the room is too dark................which lens would be best for this situation? I've heard of the "fast 50", but honestly don't know much about it.
Suggestions or links? Thanks.
vmax84
06-30-2009, 07:58 AM   #2
hello vmax
I had a similar problem and opted for the 50mm f1.4 at amazon. Its a sharp little prime with a wide aperture for lower light situations and not very expensive.
Im enjoying it immensely!
this is the link, unfortunately its gone up in price $60 since I bought it about 6 weeks ago.
Amazon.com: Pentax SMCP-FA 50mm f/1.4 Lens: Electronics
06-30-2009, 08:01 AM   #3
QuoteOriginally posted by Niki Quote
hello vmax
Thank you very much!!! I was just looking for a place to start and this helps a lot. :-)
vmax84
06-30-2009, 08:03 AM   #4
"You can use this lens with all Pentax SLR cameras, but the AF system only works with Pentax AF cameras".
Stupid question, but will my K100D camera autofocus this lens? Sounds like it will, but I want to be sure.
vmax84
06-30-2009, 08:22 AM   #5
I use the K100D Super and it auto focuses well with the FA50/1.4
Recently, prices of all lenses have gone up substantially. You may want to consider getting a good 2nd hand copy from our Photographers' Marketplace.
Personally, I actually prefer getting them 2nd hand. I tend to be too careful with brand new ones and don't get to enjoy them as much
06-30-2009, 08:31 AM   #6
QuoteOriginally posted by Just12hvFun Quote
I have purchased a lens (Tamron 75-300mm lens) on the marketplace a couple months ago with very good luck, so, yeah, good place to look.
Also, is there another lens (or lens) I should also consider? Thanks again.
vmax84
06-30-2009, 08:51 AM   #7
QuoteOriginally posted by vmax84 Quote
vmax84
You may want to consider getting yourself a wide angle prime or zoom
The DA14, DA 12-24 and DA 16-45 are good choices
06-30-2009, 08:59 AM   #8
Marc Sabatella's Avatar
Sure, any lens that has a larger maximum aperture than the kit lens would be an improvement. Figure out using the kit lens what focal length or focal lengths you want. 50mm iis one the long side for me - I prefer something more in the 30-40 range. The DA40/2.8 is relatively inexpensive if you are limiting your search to autofocus lenses. It's a better focal length for me, but at f/2.8 instead of f/1.4, that's not *as* large an aperture, so you can't get as fast a shutter speed. Fast *enough*, though, most of the time.
If you can still find an FA35/2, tht would be worth considering. And if you don't mind manual focus, there are a host of other options, too.
06-30-2009, 09:52 AM   #9
I use a 50mm F 1:1.7 & like it. I'm not sure if the 1.4 version's extra speed would compensate for its shallower DOF when wide open (1/3 faster, 1/5 less DOF); maybe someday I'll switch to the 1.4 & see. The numbers look like the 1.4 would be preferable.
Dave in Iowa
06-30-2009, 10:31 AM   #10
superfuzzy's Avatar
vmax84
the FA 35mm f/2 will be more useful than the 50mm focal lenght. 50MM just isn't wide enough for general purpose indoor family type photography. Also consider constant f/2.8 zooms, in the 17-50mm range. For my use at least, constant f4 zooms are unacceptable indoors.
Good luck!
06-30-2009, 10:58 AM   #11
for me indoor lens should be f/2.8 or fester (smaller #) that should cover you
focal length is relay depend on what you are going for , if you want to shoot the whole room you will need a wide lens. if you are going for a portrait of a person in a room you will need a longer lens
if you like zooms and you have the money get something like the DA * 16-50 f/2.8 and you done
06-30-2009, 11:11 AM   #12
Mike Cash's Avatar
vmax84
Forgive me if this question insults your intelligence, but do you understand why the kit lens is too dark and what feature of a different lens would make it better suited? Understanding that will make it easy for you to make a judgment about the suitability of any substitute lens for yourself.
It's all about the maximum aperture.
Forgive the short answer, but I have to run out the door to go to work. If you need help with this I feel certain some kind soul will be glad to elaborate on it.
06-30-2009, 11:13 AM   #13
QuoteOriginally posted by superfuzzy Quote
I'd also consider the Tamron 28-75mm F/2.8. Not real wide, but I've found mine very useful for indoor shots of mobile youngsters. Also won't break the bank, especially if purchased second hand in the marketplace.
07-01-2009, 03:03 AM   #14
Most of my shots use to be soccer, softball, etc., but am working on more indoor shots now, and am surprised how pricey the "little lens" can be!!!
Thank you to all who have posted..........a little bit of info leads me to google and then more reading!!!
PentaxForums is a great site!
vmax84
07-01-2009, 07:30 AM   #15
FA 35 f/2 hands down.
You won't find anything wider and faster for that price range.
flash, k-mount, lens, pentax lens, slr lens
Is f/2.8 enough for indoor shooting w/o using flash or tripod? shang Pentax SLR Lens Discussion 19 07-13-2010 03:22 PM
Indoor /no flash seacapt Troubleshooting and Beginner Help 22 01-08-2010 12:09 AM
Lens vs Flash for indoor use? MrApollinax Photographic Technique 63 01-05-2009 10:25 AM
2.8 Lens for Indoor Sports without Flash? joelovotti Pentax SLR Lens Discussion 7 08-13-2008 07:36 PM
PL Filter / Indoor with Flash zenzenyoyo Pentax DSLR Discussion 8 11-01-2007 04:24 PM
All times are GMT -7. The time now is 03:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
