Hello fellow Pentaxians!
I hope this review and samples will help those who have either of these lens and think about getting the other.
I recently aquired my Tamron 70-200mm 1:2.8, the last "expensive" lens I planned to buy. Its a very nice piece of equipment: well built, feels solid and although a bit heavy at 1100g, very fun to use. Before that my "longest" tele was the Pentax SMC K 135mm 1:2.5, a great prime that is sharp wide-open, and about 2 times lighter and more then 2 times smaller than Tamron is.
At some point I wanted to see how the new zoom performs against the old proven prime. So I have taken them both to the country where I allowed myself half an hour of thoughtful measurebation. I have taken about 8 shots of the different flowers with both lenses, focusing on the same areas to compare sharpness, contrast, color and bokeh. When converting to JPEG no PP was added at all ( no sharpening, no WB, no levels )
The Tamron was set to approximately the middle between 130mm and 140mm ( this lens does not report 135mm focal lengh to the camera ). Most of the pictures were taken wide-open (F2.5 and F2.8), which is by far my favourite setting, and a few were taken with both lens set to F3.5. My short conclusion is that the zoom is being both sharper and more contrasty wide-open, which comes as a surprize. The mentioned difference is gone by F3.5. In regard to colors and bokeh - the lenses are completely different, Tamron being slightly warmer and its bokeh being more smooth, which is not necessarily an advantage. The K135 image is cooler and has a proprietary rendering, specific to older Pentax glass.
Below are sample pictures. Its left as a fancy exercise for the reader to make which one is which, however I`ll name it at the bottom. These are resized images and link to full sized images at my gallery.
First series taken wide-open.
Flowers #1, Lens #1 (
full-size)
Flowers #1, Lens #2 (
full-size)
Flowers #2, Lens #1 (
full-size)
Flowers #2, Lens #2 (
full-size)
Flowers #3, Lens #1 (
full-size)
Flowers #3, Lens #2 (
full-size)
Flowers #4, Lens #1 (
full-size)
Flowers #4, Lens #2 (
full-size)
Flowers #5, Lens #1 (
full-size)
Flowers #5, Lens #2 (
full-size)
Flowers #6, Lens #1 (
full-size)
Flowers #6, Lens #2 (
full-size)
Flowers #7, Lens #1 (
full-size)
Flowers #7, Lens #2 (
full-size)
Flowers #8, Lens #1 (
full-size)
Flowers #8, Lens #2 (
full-size)
As you have probably guessed Lens #1 is the SMC K135, and #2 is Tamron.
Thanks,
Ilya.
