06-01-2010, 10:14 PM   #46
lens cap question
hey guys... just joined the family and bought a 55mm 1.8 for my canon... ordered it off keh but it didn't come with lens caps.... i have the screw mount so i could use a canon lens cap for the back, but i have no idea what size of canon lens cover would be compatible with the front....... any ideas??
06-01-2010, 10:33 PM   #47
Blue's Avatar
QuoteOriginally posted by ipratt Quote
Assuming its a Super Tak, S-M-C, or SMC, a 49mm pinch cap will work.
03-09-2011, 02:45 AM   #48
Ciao a tutti. Sono nuovo del Forum e ne approfitto subito per una domanda facile facile: che differenza c'Ŕ fra questi due obiettivi?
- Asahi Super Takumar f1.8 55mm e Asahi SMC Takumar f1.8 55mm.
Grazie per chi mi illuminerÓ!!!
03-09-2011, 08:44 AM   #49
kuuan's Avatar
Optics are the same,
most likely there is a difference in both coating and appearance.
SMC stands for Super Multi Coated, the Super Takumar is an earlier model and should have simpler coating
( some are reported to already have the then famous Pentax Multi Coating )
The focus ring of the Super Takumar is made of metal, the later released SMC got it rubberized.
In between came the S-M-C Takumar, short for the model that has 'Super Multi Coated Takumar' fully written out on it's name ring. ( on the SMC it says SMC Takumar )
The S-M-C Tak has the full metal body of the earlier Super Takumar and is the first line with the Super Multi Coating.
55mm, k-mount, pentax lens, slr lens, takumar 55mm
1.2/55mm Takumar??? porterHause Pentax SLR Lens Discussion 16 06-05-2010 11:24 PM
TAKUMAR 55MM F2 samgrom Pentax SLR Lens Discussion 5 03-04-2010 08:01 AM
Mamiya / Sekor 55mm f1.8 or SMC Takumar 55mm f1.8? -kb- Pentax SLR Lens Discussion 14 09-16-2009 05:54 AM
takumar 55mm F/2 maritimer Post Your Photos! 6 04-28-2009 12:08 PM
Fuji Fujinon 1:1.8 55mm vs. Super-Multi-Coated Takumar 1:1.8 55mm carpents Pentax SLR Lens Discussion 6 06-27-2007 05:25 PM
All times are GMT -7. The time now is 10:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
