07-06-2009, 11:52 AM   #1
Fl_Gulfer's Avatar
Takumar 55mm 1.8 ?
I picked this up on fleabay and was wondering if it looks complete.
Does this side look ok? I've never seen the bottom of a 55mm.
The complete package.
Came with a Hoya filter
07-06-2009, 11:58 AM   #2
Nesster's Avatar
you're missing the camera!
It looks complete with everything that's supposed to be there, and looks to be a good sample too.
Note the little pin in the mount at 5pm on your photo- if you get 'stuck' in Auto mode with the lens unmounted, push that in and it frees the a/m switch. It is the sensor for the open-aperture metering Spotmatics (SP-F, ES) and is designed to lock the a/m on Auto. Some people, me included, have at one time or another thought their lens defective due to this little feature.
07-06-2009, 11:59 AM   #3
kuuan's Avatar
looks very fine to me indeed..with original caps and a case..
the 55/1.8 is one of the very sharpest lenses out there, have fun!
07-06-2009, 12:09 PM   #4
Fl_Gulfer's Avatar
Thanks guys, I was wondering why the switch didn't move, that is why I thought something was missing underneath.
07-06-2009, 12:15 PM   #5
kuuan's Avatar
QuoteOriginally posted by Fl_Gulfer Quote
press the little button seen at the right lower part of your second photo, unlike the other one well seen in your third photo it hardly sticks out, but pressing it should enable you to move the A / M switch.
07-06-2009, 12:24 PM   #6
Banned
QuoteOriginally posted by kuuan Quote
that's not an OEM case, nor is the rear cap OEM. not that it really matters. your 55 looks to be all there. enjoy it, because the 55 is a stellar lens. one of pentax's true gems.
07-06-2009, 12:27 PM   #7
Blue's Avatar
Now you have an excuse to get an ES, ESII or Spot F.
07-06-2009, 12:29 PM   #8
kuuan's Avatar
QuoteOriginally posted by séamuis Quote
that's why I had written a case, but had overlooked that the rear cap was not original
07-06-2009, 12:38 PM   #9
Banned
I misread that.
07-06-2009, 12:40 PM   #10
raymeedc's Avatar
Beautiful..... seems to have an "As-New" patina. You were lucky enough to get one with the older, more desirable metal focusing grip. Too many of the normal Multi coated Takumars came with the later rubber focusing ring..... great lens.
07-06-2009, 12:47 PM   #11
Banned
QuoteOriginally posted by raymeedc Quote
whats wrong with the SMC version? or S-M-C with rubber ring? I have an auto, super, s-m-c and an smc and I find the smc to be the leader of the pack. I prefer the auto because I actually like its lack of coating but I just don't quite get why people always seem to down the last generation takumars... build quality is just as good.
07-06-2009, 01:07 PM   #12
Nesster's Avatar
The rubber grip comes in handy... in sub-zero weather when you get the urge to lick your lens
07-06-2009, 01:16 PM   #13
Just1MoreDave's Avatar
Inside, they appear to be the same, though I haven't compared parts. The screws can be different on older lenses. (I read somewhere that the slotted screws were dropped to comply with an international standard to use phillips-style.) It could be just my personal luck, but I've had several distance scales become unglued only on rubber-grip lenses.
07-06-2009, 02:35 PM   #14
Fl_Gulfer's Avatar
I just noticed that the case says Vivitar on the bottom though I no not which lens it was made for. Thanks again guys, now I just need a 85mm 1.8 or 1.9 to complete my little Tak collection.
Super Takumar's 200/f4,135/f3.5,55/f1.8,28/f3.5
07-06-2009, 04:58 PM   #15
raymeedc's Avatar
Absolutely true. Just a personal preference for the feel & look of the older metal grips..... nothing more or less.
55mm, k-mount, pentax lens, slr lens, takumar 55mm
1.2/55mm Takumar??? porterHause Pentax SLR Lens Discussion 16 06-05-2010 11:24 PM
TAKUMAR 55MM F2 samgrom Pentax SLR Lens Discussion 5 03-04-2010 08:01 AM
Mamiya / Sekor 55mm f1.8 or SMC Takumar 55mm f1.8? -kb- Pentax SLR Lens Discussion 14 09-16-2009 05:54 AM
takumar 55mm F/2 maritimer Post Your Photos! 6 04-28-2009 12:08 PM
Fuji Fujinon 1:1.8 55mm vs. Super-Multi-Coated Takumar 1:1.8 55mm carpents Pentax SLR Lens Discussion 6 06-27-2007 05:25 PM
All times are GMT -7. The time now is 12:47 PM. | See also: NikonForums.com, part of our network of photo forums!
