Originally posted by MattGunn YES it should be quite straightforward to repair.
I have not opened / repaired a 135 takumar but I have fixed a 55 1.8 and a 50 1.4 and I suspect the general assembly will be the same. The focus ring is usually secured to the focus mechanism with 3 small screws which can come lose over time. The rattling is probably one of these which has come right out.
You're right,
if the lens is an M42 mount, that's probably the issue. The K-mount "Bayonet" version is constructed differently, however. And this part is trouble for both lenses:
Quote: Details of the disassembly and repair of a takumar 50mm 1.4 is described and shown pictorally here:
Those instructions apply to a lot of Takumar and Pentax lenses but will not allow access to the focus ring screws on the M42 mount 135mm f2.5 lens. On those lenses, the whole front lens group unscrews. Just focus to the minimum distance and unscrew the barrel. I think (in this rare case, I have sold all mine) that you can see the three focus ring screws right there, though a long screwdriver is required. If not, this is at least the first step. It looks like there are grub screws around the focus ring; those might need to be loosened if you can't see the focus ring screws.
Like I said, the "bayonet" version is different. Although the front group unscrews in the same way, it doesn't get you anywhere. Peeling off the rubber grip allows you to get to three grub screws which affect the focus ring somewhat, but I don't think it's the whole story.
