Originally posted by photolady And I'm debating whether I really need this lens adapter. I have the 135mm Macro which does a decent job taking macro shots. And I have a set of closeup lenses too. And then I have this great 70-300mm Macro that does a decent job too.
Well, experimenting on film is a *lot* slower and more expensive than doing so on digital. So it might indeed take quite a bit longer to get the hang of it, and might not be worth it. But:
- If your 135 Macro is 1:1, then I'm not sure what you were ever looking at Raynox for? My guess is that is isn't 1:1, though.
- The 70-300 only does 1:2.
- The closeup lenses can give 1:1 but are junk; no way will they produce results that even come close to the Raynox in quality, nor are they any easier to use if you're trying to get anything approaching 1:1 magnification. They are basically the same as far as how you use them - they are just *much* lower quality.
- The extension tubes would be fine, but give more magnification with shorter lenses. Most likely, something in the 50-100 range would give 1:1 magnification. Depends on how long the tubes are. Problem is that getting 1:1 magnification with a shorter lens means even shorter working distance than with the Raynox, and they aren't particularly easier to use, either.
So I'd say your best options are the 135 Macro if it provides enough magnification, but the Raynox otherwise. The other options either provide less magnification, less quality, or are even harder to use. No one ever said macro photography was easy, though - no matter which option you go, if you want anything approaching 1:1 magnification, you're going to burn through a bunch of film experimenting and practicing.
