Originally posted by Marc: Right, that much is the phenomenon I already referred to. Independent of whether the *size* of the *in-focus* area is the same or not, it does seem to be true that the *appearance* of the *out-of-focus* areas will depend on focal length for a given magnification.
That's true; an area out-of-focus at the same distance behind the subject looks *much* blurrier with a long focal length lens than for a short focal length lens at the same magnification.
Actually, the apparent background blurrieness is in the ratio of the focal lengths for the same f-number and magnification.
Dave
EDIT: According to my estimates based on thin lens theory an out-of-focus point a real distance Z behind the plane of focus is a disk of diameter d given by:
d=(Z/N)(h/ho) [m/(1+1/m)]
where N is F-number, the h/ho ratio is the size ratio behind the focal plane due to perspective, and m is magnification at the focal plane.
While this is not the most compact way to write the equation, it embodies simple parameters important to the photographer:
1) The out-of-focus spot size tends to increase in proportion to distance behind the focal plane.
2) The out-of-focus spot size decreases as F-number increases.
3) The out-of-focus spot size behind the focal plane is decreased by the perspective effect (countering effect #1).
The net effect is that long lenses tend to create fuzzy backgrounds because the perspective effect does not greatly decrease the size of out-of-focus points. These results are consistent with observations.
