Originally posted by BBear Hi Paul,
You are absolutely right, and i did get the "bias" on the review. And to be honest, the discussion was changing directions so no, i did not read about the rain part.
The biggest issue for me is NOT paying $200 and the lens not resisting the desert... the biggest concern is NOT having a lens to shoot during the festival, because most likely will be the only lens i'll be taking there...
I totally get your concern, I was thinking more in terms of water resistance, whereas dust can more easily penetrate, and obviously cause more long term repercussions. Hopefully I will have the lens by the end of next week in plenty of time to give you a good idea of the build; I have the 50-135 to compare it to, so even if I don't actually put it through a gauntlet, I can at least give you a good visual inspection!
It is rather disapointing that pentax doesn't give hard details on these kinds of things (the other side to the coin - it is great they actually make lenses this durable...). Maybe they have a silent replacement warranty? The odds most people would actually take their lenses into bad enough conditions that they would get permanently damaged are probably slim enough that this may in fact be the case.
