07-09-2009, 02:28 AM   #1
yyyzzz's Avatar
Pentax "A" lens and "F" 1.7X converter on K10d
I am using an "A" lens and a SMC F 1.7X converter. My K-10d controls the apertures well, but it does not recognize the focal length of the "A" lens or the lens attached to my F 1.7X converter.
Is this normal? The K10d seems to need the focal length value to have the lens properly stabilized.
Thanks a lot.
07-09-2009, 03:17 AM   #2
Ben_Edict's Avatar
QuoteOriginally posted by yyyzzz Quote
Thanks a lot.
That's normal, you have to dial in the focal length manually, since the camera cannot know it - The old A lenses don't have a micro chip with that information.
Ben
07-09-2009, 03:37 AM   #3
If your have SR ( shake reduction ) on when you turn on your camera it will automatically pop up on LCD to set focal length. Otherwise you will find in menu. Good luck.
07-09-2009, 03:52 AM   #4
yyyzzz's Avatar
Thanks Man!
Yes. I do manually put in the focal information. But it is hard for zoom lenses. I might have to put a middle value in it.
It is hard to understand why my F 1.7X converter does not convey the focal information, even if attached lenses are FA or F lenses.
07-09-2009, 05:04 AM   #5
Ben_Edict's Avatar
The 1.7x AF-adapter is very old. At that time, nobody anticipated Shake Reduction or even EXIF data. So there was no need to add any intelligence into the adapter. We cannot expect old equipment to perform like current one - and we should be happy, that we can still use it at all.
Ben
1.7x, converter, k-mount, k10d, length, lens, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 33 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
What is difference "APO" and "ED" glass in a lens? kathyk Pentax SLR Lens Discussion 4 03-06-2008 08:59 AM
All times are GMT -7. The time now is 12:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
