Originally posted by borno As you decrease the sensor size, the DOF decreases, as they say on their webpage. So you need only a smaller aperture to begin with, since the bokeh will basically "multiply" in size. What they say is correct, but their calculator is either misleading or wrong. Think about it logically instead of relying on a calculator and you'll get it.
EDIT: I found out why it's misleading. They are not taking into account the same image/print size. They are using hypothetical direct crops of larger sensors. If you take a 12mp full-frame image at 200mm f/2, you would need a 135mm f/3 lens to give the same image on a 12mp 1.5x crop APS-C camera.
Also, the reason why compact digital cameras have such a deep DOF is because their lens' focal lengths are around 2-6mm at f/2.8 to start with, not because of their sensor size. If you put a 100mm f/2.8 lens on a compact digital camera sensor, the image would have such shallow DOF it would be almost impossible to get any subject fully in focus. Who wrote this errant guide?
