Originally posted by netuser Hi
This morning I tried again on k20d and same thing, only screw.
Change the lens to k200d and I get SDM.
I made this changes a couple of time and sdm "only failed" one time on k200d.
Very odd.
I can't figure out what is happening.
Edit: And on screw this lens really sucks on k20d
so much hunting and AF-C is not fast at all. On the k200d with sdm working everything is smooth and fast.
netuser,
That's really odd. I assume that when you put other autofocus lenses on the K20d, they work fine. Which sort of says that the AF circuit on the K20d is fine???
Have you installed the lastest ver 1.3 firmware on the camera?
Do you have different batteries in K200 vice the K20 (of course, i just remembered the K200D has aa batteries) This kind of implies that battery voltage is making a difference. Try a freshly recharged battery in your K20D, or perhaps a different one.
Also, in an old thread on dpreview, there was a discussion on the DA 50-135/16-50 about how a coupla guys fixed their SDM problems by just cycling their AF circuits by focusing on something close, then something far away, and then repeating it several times. Apparently the problem got less and less and then went away.
Regards my only SDM lens, the DA*300, i've not had any problems wtih the SDM AF. It was bought in 2008 in the fall and is working fine. No hangups ever. I just focused on a brick wall in shade inside my house but sunny outside. It focused fine and locked all the way to aperture F22 at 0.7" shutter in AV, AFS. I tried at each aperture
