07-15-2009, 07:03 PM   #1
What is the difference bwt WR and DA* lenses?
07-15-2009, 07:34 PM   #2
ManuH's Avatar
QuoteOriginally posted by rdrum76 Quote
Technically only the SDM, all DA* are SDM (in lens motor).
07-15-2009, 08:53 PM   #3
Pentaxor's Avatar
DA* is a bit heavy because of SDM. and also faster than WR. IQ is debatable as of the moment.
07-15-2009, 10:04 PM   #4
Andi Lo's Avatar
DA* iq is supposed to be really good while WR is just a WR upgrade of the normal (good) lenses. 16-50 is a bit suspect honestly.... although people that have good copies seem to love it.
07-16-2009, 06:02 AM   #5
Matthew's Avatar
Metal v Plastic
The DA*s I'm familiar with are largely built out of metal, while I assume the WRs will have more plastic and lighter construction like their original versions. Sometimes light weight is good, but they use metal for the top of the line for a reason.
DA*s are usually internal focus which helps reduce the amount of air that has to be pumped in and out of the lens each time it focuses, thus reducing dust contamination. Weather seals used on the WRs must be able to pass air to allow for the change in size with focus and zooming, but then the DA*16-50 has to be able to do this also.
07-16-2009, 10:43 AM   #6
Marc Sabatella's Avatar
The "*" lenses have a long history of being the finest quality lenses Pentax makes in terms of both build and optics. The recent ones also happen to be weather sealed and feature SDM. The WR lenses are simply sealed versions of more ordinary lenses.
bwt, da*, k-mount, pentax lens, slr lens, wr
What's the difference between K and M lenses? ismaelg Pentax SLR Lens Discussion 17 02-02-2010 02:48 PM
Please explain the difference in these 2 lenses J.Scott Pentax SLR Lens Discussion 2 12-09-2009 01:10 PM
Difference between F and FA lenses?? mr tibbs Troubleshooting and Beginner Help 4 04-17-2009 09:50 AM
what is the difference bwt exporting to 8-bit or 16-bit tiffs? rdrum76 Photographic Technique 3 01-22-2009 01:51 PM
What's the difference between these lenses? (Sigma) Tom M Pentax SLR Lens Discussion 6 09-17-2007 05:31 PM
All times are GMT -7. The time now is 05:03 PM. | See also: NikonForums.com, part of our network of photo forums!
