07-16-2009, 04:19 AM   #1
DSLR-SLR lens misery
Hi everyone! I have a Pentax K-m with 18-55 lens, and I'm thinking about getting a teleobjective. I found a pack wich contains a
Pentax MZ 50 + a Cosina 100-300 lens. I'm wondering if i could use my lens with both bodies vica-versa with or without AF. They have the same type of hotshoe for flash, i guess, but i'm not sure about it. So anyone can help, please answer! Thanks!
07-16-2009, 04:30 AM   #2
Ash
Community Manager
Ash's Avatar
Welcome to the forum.
Firstly, you have a very capable camera in the K-m.
Pentax prides itself with having the backward compatibility with any lens that will mount to the camera - which is true, any lens that fits will work, and the SR mechanism will still be available. So although your 18-55 kit lens is not supposed to work on the MZ-50, any lens you put on your K-m will definitely work, as long as you've indicated on the menu option that the camera should accept non-A lenses (for M lenses you want to fit on the K-m).
As for flashes, you'll find that unfortunately the K-m does not have TTL provisions - so a TTL flash that would normally work on the MZ-50 will not behave as a TTL flash on the K-m. Rather, it will work fine as an M flash (manual settings) in M mode on the camera. Though if you're looking for an auto flash for the K-m, best to go with a P-TTL capable flash.
All the best in that.
07-16-2009, 05:21 AM   #3
MoiVous's Avatar
Welcome to the forum!
I'm sure you'll have a great time with both your new toys!
Your MZ-50 has the crippled KAF mount - see Bojidar Dimitrov's Pentax K-Mount MZ50 pages (there are heaps of other specs too), so the AF feature and auto aperture work fine.
The DA18-55 that came with your K-M should work with the MZ-50, but its designed for APS-C sensors (smaller than film), so it will probably produce a vignetting effect.
Whereas the Cosina 100-300 should work fine on the KM, and give you a 35mm equivalent of 150-450mm (ie multiply the focal length by 1.5 to find what its 35mm equivalent). Not sure about its AF or other functionality.
WARNING: You may have a problem with older flash units on your K-M - older flash units had high voltages across the contacts that can fry your digital camera electronics.
Enjoy!
07-16-2009, 06:35 AM   #4
to make it clear, i don't have the mz50, i'M just thinking about buying one. My actual regular camera is a zenit TTL with pentacon 4/200 tele, and with helios 2/58 lens. I was planning to buy a converter so that i could use the pentacon lens with my K-m in manual mode, but now i think the best would be if i can sell the zenit stuff, and buy a regular pentax machine with an AF teleobjective wich is compatible with my K-m vica-versa. However I don't know much about this compatible-or-not-compatible stuff, so if you have any ideas pleas post it.
07-16-2009, 08:05 AM   #5
Andi Lo's Avatar
K-M + cosina 100-300: You didn't tell us whether the lens is an AF lens or not, if it's an AF lens that works with MZ-50's AF, then it should work just fine on the K-M
MZ-50 + DA18-55: Looking at dimitrov's site I'm pretty sure that MZ-50 has an in-body aperture control so the lack of aperture ring on 18-55 shouldn't be an issue. Like said above used above 23mm you shouldn't have an issue, under 23mm you'll have vignetting.
Unless the MZ50 and cosina package is under 60$ and is actually an AF lens, I would just get a DA 50-200 really as it's cheap enough and relatively decent performer.
k-mount, lens, pentax, pentax lens, slr lens
newer film slr lens... dslr camera... ? CEWren Pentax DSLR Discussion 8 09-06-2010 08:25 PM
slr pentax lens... work in a dslr? CEWren Pentax SLR Lens Discussion 16 09-02-2010 06:23 AM
Lens from slr to Dslr perception-of-light Pentax Camera and Field Accessories 2 02-20-2010 12:09 PM
Old SLR Lens Work on DSLR Camera? TexasTom Pentax SLR Lens Discussion 9 11-04-2007 10:59 AM
Some Quick SLR to DSLR Lens Questions? msprout Pentax SLR Lens Discussion 6 05-22-2007 04:01 PM
All times are GMT -7. The time now is 12:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
