07-17-2009, 03:06 AM   #1
Pentax DA 15mm -and use of filters
What is the experience of using filters on the 15mm limited lens? I am considering buying the lens but would like to be clear on these points.
from photos of the lens it appears that the lens hood does not fully retract.
The lens has a 49mm filter thread.
Some specific questions.
does the lens vignet when using screw in filters , - can you use a protector filter plus a polariser without vignetting?
can you use a square filter system such as LEE and how do you attach the holder.
I wondered if you used one screw-in filter would this then enable the LEE adaptor to clear the protruding lens hood.?
any comments on vignetting with square filter systems with this lens?
How does the performance of this lens compare with the pentax 12-24mm lens?
thank you
Paul
15mm, filter, filters, k-mount, lee, lens, pentax, pentax da 15mm, pentax lens, slr lens, square
DA 15mm LTD and GND Filters trublubiker Pentax SLR Lens Discussion 5 10-24-2010 02:42 AM
using filters with DA 15mm Limited olenl Pentax SLR Lens Discussion 11 08-21-2010 08:31 PM
For those with a DA 15mm who use Cokin P sized filters... Andrew Faires Pentax SLR Lens Discussion 0 02-16-2010 07:29 PM
Experience with filters on the DA 15mm? JamieP Pentax SLR Lens Discussion 2 10-21-2009 12:38 AM
What should be the maximum price for Pentax-A 15mm lens as the DA 15mm is coming up? Mitch34 Pentax SLR Lens Discussion 6 06-24-2008 04:40 PM
All times are GMT -7. The time now is 11:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
