I have a K100D. I am a NEW dSLR user, but I'm not a stranger to photography.
I just recently realized that Ricoh lenses fit on Pentax cameras, and I just happen to have a Ricoh lens.
There is no identifiable info on the lens, [it looks like the protective outer lens is missing]. If the manual is original it is from a Ricoh XR-S camera.
On the outer rings I see that the aperture range is from 2.8 to 16. I can't find any focal range info other than the dial turns from 2-30 feet to infinity. There is no 'A' anywhere on the ring.
I have the menu selection on my K100D to accept other lenses.
My question is, how do I use this lens??
I understand that I will need to manually focus, but where do the other settings come into play? Do I set it at Av? If so, what happens when I turn the aperture dial? How do I know when I've got perfect exposure?
I tried a few shots, and through trial and error ended up with some decent results, but I obviously can't use trial and error for every shot.
I have recently ordered a Pentax M 50mm 1.7. Will the above answers apply to this lens as well?
Thanks so much in advance if you can shed any light on this for me!! I appreciate it and I need all the help I can get.
