Originally posted by Igilligan The 44M has a A/M switch. On my K20, if the switch is in A the lens is wide open no matter what the Ap is set to. In M it goes to what ever you set the aperture to. So if I forget and it is in A mode the shutter speed stays the same since the lens is always wide open.
I tend to focus with the switch on A, then meter on M
I dont know if it works the same on the P30 but it is worth a shot...
o.k.... i have just realized what the problem is.... as per this thread:
https://www.pentaxforums.com/forums/post-your-photos/40719-helios-44-m-first-test-shots.html
mine too has no A/M switch, but if i hold the pin down manually, then yes, the aperture blades work, so essentially it's stuck wide open at f2.
does anyone have any workarounds for keeping the pin stuck down because when you screw the lens onto the mount nothing on the camera body/mount holds that pin down in place.
cheers!
