Originally posted by Buddha Jones That brings up another question, whats the deal with extension tubes?
As someone else said, extension tubes increase the magnification factor that the lens is capable of producing. They do this by pushing the lens further from the film plane (or sensor) effectively increasing the focal length, thus increasing the magnification. However, by doing so, they also eliminate the possibility of focusing to infinite by quite a lot, depending on the size of the extension. In the case of the ant photo I took, I had a standard 3 tube stack of extension tubes, which is about 60mm total extension. Each tube is a different length, so you can vary the magnification ratio.
The real beauty is that there is no glass at all in an extension tube. They are simply spacers that go between the lens and the body. Because of this, they do not have any impact of the image quality or aperture of the lens, contrary to teleconverters. So for macro work, they are great as they won't degrade the excellent image quality of a macro lens. And for normal lenses, they are an inexpensive way to turn a lens into a macro lens. A good 50mm lens becomes a really nice macro lens with a set of tubes.
For Pentax, they come mostly without contacts to transmit aperture data back to the camera. Several companies do make extension tubes which have the electrical contacts, but they are much harder to find, and more expensive. I have Vivitar Auto extension tubes, which do have the contacts.
Hope this helps clear it up some for you.
Andrew
