Originally posted by netuser Not even at 1 pm full sun for surf images ?
(Azores Islands sun
Pal is quoting manufactuer's specs. The truth is quite different. You
can achieve autofocus with an aperture of f/8 in good light, and even in decent light with certain lens combinations. For example, I have managed correct AF with the following lens + TC combinations:
- Sigma APO 70-300mm @300mm + Tamron 1.4x = 420mm f/8
- Tokina AT-X 400mm f/5.6 + Tamron 1.4x = 560mm f/8
- Tokina SD 400mm f/5.6 + Pentax FA 1.7x = 680mm f/9.4
That last combo only autofocuses in bright light, but the other two work fine in the shade during a sunny day.
All these combos worked with screwdrive AF. SDM, however, is a different beast. I tried the Tamron TC on the DA* 50-135mm f/2.8 and it wouldn't lock focus. It would hunt back and forth between close and infinity but only lock focus in
really bright light with a
very high contrast subject.
I don't know why SDM makes a difference, but it does.
Bottom line: If you manage to disable the SDM and get the screwdrive working, it's possible that you
will get AF on the beach. If you do, the next question will be whether the IQ is any good.
