07-21-2009, 03:41 AM   #1
K-135MM f/3.5 aperture not responsive
I'm a newbie and hope someone can help here.
I purchased a K135 f/3.5 off of ebay and got hosed. The aperture dial doesn't do anything - the blades do not move. The aperture lever cause a very small wiggle in the blades.
The blades are stuck in a stopped down position (smallest opening). Any ideas of how to fix the problem? Or do I need to shoot outside in full light only?
07-21-2009, 03:43 AM   #2
Also, will this ruin my K100d if I use it in "Manual" mode with a stuck aperture?
07-21-2009, 03:49 AM   #3
Also, the aperture dial has free movement and seems fine. It rotates a good ways and then stops and rotates the other way. No stickiness at all.
07-21-2009, 07:22 AM   #4
wavecurrent's Avatar
I think this is posted in the wrong group, it should be in the "Pentax SLR Lens Discussion" group!!
How does the blade looks, are there any grease or oil on them? That can be one cause for them to stick. What happens if you try to move the aperture level gently at the rear of the lens, can you see the blades move?
In the link below you have some info on these matters!?
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/44776-disassem...ce-needed.html
Mike
07-21-2009, 10:43 AM   #5
The lens look astoundingly clean for a K version lens. I don't know how to tell if there's grease or oil, but I shined a light and noticed slight discoloration in the tips of the blades. Not sure if that was the reflection of my flashlight or not.
The blades get a tiny bit larger if I move the aperture lever - looking at the rear of the lens.
However, the aperture dial does NOTHING.
Is this common for older manual lens? Surprising since it looks so well-kept and newish.
07-21-2009, 01:23 PM   #6
QuoteOriginally posted by joeschmo Quote
It sounds like you should ask for a refund & return the lens if the seller said it was ok. It is not functioning correctly and is a non-trivial problem to fix most likely.
Ebay should support you on this one.
Dave
aperture, blades, f/3.5, k-mount, pentax lens, slr lens
135mm 3.5 with no aperture control tortoise Pentax SLR Lens Discussion 3 02-03-2010 05:11 PM
Sears 135mm: Av stop-down does not match aperture ring aerodave Pentax SLR Lens Discussion 2 11-01-2009 02:24 PM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
For Sale - Sold: Soviet Tair-11A 135mm/2.8 Screw Mount M42 ( 20 Aperture Blades! ) arpaagent Sold Items 6 03-26-2009 05:23 AM
Sears 135mm f2.8 K-mount -- using aperture ring? bikerboy_ro Pentax SLR Lens Discussion 5 11-27-2008 02:20 PM
All times are GMT -7. The time now is 11:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
