07-21-2009, 09:07 AM   #1
jcool's Avatar
sakar lens
I have two sakar camera lenses, one reads "sakar aux telephoto lens distance to object 2M-00 made in japan" the other says same except "wide angle" are they worth anything or can I get an adapter to try them on a k20d they have a smaller screw on connection, I have had the lenses for over 20 years which have never been used still in plastic wrapper and leather case with front and rear lens caps on. If I remember correctly I might have received these with a ricoh camera I broke and threw out years ago, I'll post a photo of them as well a little later. They appear to be very well made and i guess considered prime ? lenses......Thanks Jeff
07-22-2009, 09:47 AM   #2
Talisker's Avatar
Sorry to disappoint, but they probably aren't worth very much unless you can find a completist collector. The important bit is in bold "sakar aux telephoto lens" - they would have been designed to screw onto the front filter mount of a standard lens (particularly on a camera with a fixed lens - was your old Ricoh a fixed lens rangefinder?) to give a (short) telephopto and (modest) wide angle effect. The results weren't usually that wonderfull.
You can buy similar accessory lenses and mounts to work on some digital compacts.
07-22-2009, 09:39 PM   #3
jcool's Avatar
Thanks, no disappointment, I just hate to throw things out and was not sure what to do with these, your input is greatly appreciated, maybe put on e-bay instead of throwing out.
camera, k-mount, lens, lenses, pentax lens, sakar, slr lens
trick, or treat? Sakar 28-200mm f/4? jimr-pdx Pentax SLR Lens Discussion 3 06-18-2011 09:36 AM
Z-1 & Sakar 717AF Flash unit ScotIslander Pentax Film SLR Discussion 0 08-13-2009 09:38 AM
Sakar MC auto zoom 80-200 lens Shefali Pentax DSLR Discussion 2 02-26-2007 03:35 AM
Sakar 50mm 1.7 automatic lens? wipearl Pentax SLR Lens Discussion 0 02-17-2007 04:57 AM
anyone know who makes Sakar lenses? slip Pentax SLR Lens Discussion 3 11-21-2006 09:34 PM
All times are GMT -7. The time now is 06:41 AM. | See also: NikonForums.com, part of our network of photo forums!
